Code question
Old Mar 10, 2005 | 08:13 PM
TurboTed's Avatar
Code question
Checked for codes and 66 comes up before going back to 00. What does it mean?
Old Mar 11, 2005 | 06:48 PM
TurboTed's Avatar
ANY CODE BUSTERS?? It comes up as 66 05, next time 66 06, etc..????
Old Mar 12, 2005 | 03:48 PM
SteveZ's Avatar
How are you checking for codes...?
Old Mar 12, 2005 | 04:13 PM
Artie04's Avatar
This is an instrument cluster error code and you get them by holding in the trip rest button while turning on the key. A self test of the lamps and gauges is done first and then any errors are displayed. The errors are two two digit numbers the first two digit number is the error code and the second two digit number is the number of times the key has been cycled on since the error happend.
Error 66 is "All door lock output circuit shorted to ground or voltage."
Old Mar 12, 2005 | 10:04 PM
TurboTed's Avatar
Does that mean there's a short in the electrical system??
Old Mar 12, 2005 | 10:14 PM
TurboTed's Avatar
Artie- that's the way I check for codes.
Old Mar 14, 2005 | 07:33 PM
djbikeman's Avatar
codes vs hours
I think you guys are viewing engine hours. Thats why its changing by one every time you do it. To check engine codes, you turn the key on three times (without starting), the codes will show if there are any, then it will say "done".
I could be wrong.
Read this : http://www.tdr1.com/forums/showthrea...k+engine+hours
Old Mar 14, 2005 | 09:01 PM
handymantim's Avatar
Artie has it right.
The test that TurboTed is doing is the instrument cluster self check.
Do your doors lock and unlock OK?
Old Mar 15, 2005 | 07:17 PM
TurboTed's Avatar
Yeah, they're fine.
Old Mar 16, 2005 | 07:17 PM
TurboTed's Avatar
I mentioned this code to a dealer today. Service manager said that checking for codes this way isn't that reliable. He said they usually wait for trouble light to come on, or problems to occur, then check codes on their diagnostic computer. Comments??
Old Mar 16, 2005 | 07:30 PM
Your code could have been set by a temporary glitch which is why the dealer made the comment, "not reliable". But that's true for ANY code whether it's the instrument cluster self check or the ECM/PCM codes. Since your door locks are working, I'd say don't worry about it and press on. But to confirm, do your door locks work from both the driver's and passenerger's switches and the key FOB? If they do, press on and don't worry about it.
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
TEDHRS
Nov 9, 2002 12:35 AM
