code po193
Old Jun 22, 2008 | 10:31 PM
fullthrottle07's Avatar
code po193
could someone tell me what sensor that this code is referring to thanks
Old Jun 22, 2008 | 11:18 PM
BigIron70's Avatar
Cummins Guru
P0193-FUEL PRESSURE SENSOR VOLTAGE TOO HIGH
The fuel pressure sensor is mounted vertically near the top/center of the fuel rail
The fuel pressure sensor monitors actual high-pressure within the fuel rail. An output signal from this sensor (relating to fuel pressure) is sent to the Engine Control Module (ECM).
To prevent leaks, sensor must be tightened to 70 N·m (52 ft. lbs.).
Old Jun 22, 2008 | 11:26 PM
so do i just need to tighten the sensor and all will be good
Old Jun 22, 2008 | 11:31 PM
BigIron70's Avatar
Cummins Guru
I could give you the diag procedure, but you should still be under warranty. Do you have access to a scanner?
Old Jun 22, 2008 | 11:43 PM
BigIron70's Avatar
Cummins Guru
While monitoring scan tool, connect a jumper wire between the (K181) signal circuit and the (K915) return circuit of the Fuel Pressure sensor connector.
Does the DTC P0192 set?
Yes
Replace the Fuel Pressure Sensor
Old Jun 22, 2008 | 11:49 PM
BigIron70's Avatar
Cummins Guru
P0148-HIGH PRESSURE COMMON RAIL (HPCR) CHECKSUM
I would take care of fuel sensor problem first.
HIGH PRESSURE FUEL PUMP
INTERMITTENT CONDITION
Dignostic Test
1. OTHERS DTC'S PRESENT
With the scan tool, read DTCs.
Are any other DTC's present?
Yes
Repair other DTC's first.
metal_miner
Sep 7, 2008 10:37 PM
fullthrottle07
Jun 23, 2008 07:12 AM
jwb600
Aug 20, 2007 10:58 PM
CTD NUT
Apr 5, 2005 04:45 PM
