Code P0633
Old Mar 15, 2010 | 06:26 PM
cwert87's Avatar
Code P0633
Just drove the truck and code P0633 popped up!need some help telling me wat it is. also 2146 2149 0201-6!thanks for ur help!
Old Mar 15, 2010 | 07:20 PM
hector's Avatar
p0633=Immobolizer key not programmed -ECM/PCM
P0201= Injector circuit open cyl #1
p2149=fuel injector group B supply voltage circuit / open
p2146= same as above except group A
Old Mar 15, 2010 | 07:26 PM
cwert87's Avatar
wat do all these mean?
Old Mar 16, 2010 | 11:09 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
sounds like a corrododed connector. I'd pull the ECM, PCM wiring harness connectors (after disconneting the batteries) and clean good with contact cleaner then reassembly a few times so they make good contact and then clear the codes and run it.
Old Dec 29, 2011 | 10:41 AM
heykw's Avatar
did it work?
erniew
Dec 29, 2011 02:22 PM
kzimmer85
NCDTR #18
Feb 23, 2009 02:35 PM
3500eh
Dec 25, 2006 10:22 AM
PThree
Mar 23, 2005 03:14 PM
v12xke
Mar 2, 2004 01:02 AM
