code P0628
Old Jun 14, 2006 | 02:25 AM
973604x4's Avatar
code P0628
P0628-yes the lift pump code.
I did a search...came up with people throwing this code with a FASS installed. Truck runs fine and strong....but i just happened to check it today since my DTT, FASS, Edge, and AFE installs and this is the code it gave me.
Is this code because of the missing relay with the FASS system?
would a fuel pressure gauge help monitor to see if the CP3 is really dying?
Old Jun 14, 2006 | 05:46 PM
973604x4's Avatar
anybody?????
the code won't clear so i'm assuming it MUST be the missing relay for the FASS system.
Old Jun 14, 2006 | 09:43 PM
CButler610's Avatar
I can't believe nobody else will answer. The code is normal as the relay is missing and the ECM is looking for voltage here. I don't think this will cause any adverse driving or power problems. If you want to eliminate the condition entirely, you caln plug the relay back into the original position and snip the black wire (ground) at the sending unit harness on the tank. The FASS instructions are not very well updated.
A fuel pressure gauge is always a good idea and a good diagnostic tool. Just more money.
Chris
Old Jun 14, 2006 | 11:11 PM
973604x4's Avatar
THANKS man, i just wanted to confirm what my problem is.
Raspy
Dec 22, 2016 06:34 PM
nesbob
Jan 22, 2008 10:04 PM
johndeere01
17
Nov 10, 2007 11:10 AM
brockstar
Feb 13, 2007 10:07 PM
DirtEater
21
Feb 6, 2007 06:26 PM
