Code P0299 Low Boost
Old May 31, 2011 | 10:56 PM
jgiachino's Avatar
No new mods or other changes to my truck...havent ever had this code and now i've gotten it 4x's in the past month....put's the truck in reduced power mode....
Any common causes? e.g. boost leak, boost fooler issue, reset apps/throttle by wire? Truck run's fine otherwise so not sure....
Thoughts appreciated.
Old Jun 1, 2011 | 08:36 AM
carl48's Avatar
this code is usually associated with the 14 cm housings. i have never seen the 62-65- 13 throw this code. try changing the map sensor, i think it might be reporting the incorrect pressure. check for boot leaks. your 06 has the metal ends on the intercooler so check it last
Old Jun 1, 2011 | 08:59 AM
jeephauler's Avatar
I used to get this code pretty often and tried everything to figure it out however nothing worked and I just lived with pulling over and clearing the code with the Smarty.
Come to think of it I have not had the code since I did the new intake. I know my old set up had a very dirty filter which may have been restricting flow.
Maybe check your intake and filter for restrictions.
Old Jun 2, 2011 | 08:14 AM
carl48's Avatar
use a wix 49946 filter
Camofoot
0
May 31, 2009 08:18 AM
randallp84
28
Oct 8, 2008 03:58 PM
Dodgezilla
Jul 24, 2007 06:34 AM
benterry
Feb 20, 2006 09:56 AM
williejeeper7
Apr 7, 2005 06:42 PM
