code p0148
Old 11-09-2009, 07:07 PM
rjm022's Avatar
code p0148
on the way home from work-truck had no power-would not go over 30pmh. truck lugged/jerked-wanted to die when i hit the go pedal. came home and looked up code p0148 and seen it covers a multitude of items,etc. i decided to replace the fuel strainer to the fass and the fuel filter even though they only had about 6,000 miles on them. seemed to cure the problem- drove the truck for 10 minutes/drove it hard-truck back to normal (fingers crossed) so,here is my question ( if i did not already answer it myself) could i have had a dirty/plugged fuel filter which threw that code?
Old 11-09-2009, 09:22 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Sounds like you need to buy your diesel fuel some where else. Might be getting rust or water into your tank.
Old 11-10-2009, 05:01 PM
rjm022's Avatar
truck ran fine this morning. buddy cleared code for me tonight. left his house-truck sputtered again and stalled this time. restarted truck power came back truck ran fine on the rest of the way home- checked for the code-not present! getting stumped-now!
Old 11-10-2009, 08:23 PM
FastTaco's Avatar
Mine did this after fuel pump install. Ended up I didn't put teflon on a fuel fitting and it was sucking air in. Couple wraps of tape and all is good.
smncrst
10-27-2009 09:10 PM
nofender
07-13-2006 02:26 PM
inline6power
07-07-2006 11:37 PM
Batts
13
06-02-2006 02:35 PM
StealthRam
09-21-2005 02:27 PM
Quick Reply: code p0148
