code 1475
Old May 22, 2005 | 12:44 AM
Meatball's Avatar
code 1475
code 1475, i searched everywhere, what does it mean, i cant find it, i looked at the list on this site and OBD II's
Old May 22, 2005 | 12:21 PM
rockwithjason's Avatar
From the 2000 factory manual
p-1475 Auxilliary 5 volt output too high
possible causes
5V supply circuit short to power
map sensor wiring harness intermittent
map sensor wiring observable
Engine control module
I can post the flow chart if needed
Old May 22, 2005 | 02:31 PM
Meatball's Avatar
what the heck is that, what should i check out?
Old May 23, 2005 | 06:37 PM
From the 2000 manual
1. start engin and let idle. disconnect the map sensor connector. check connector and clean/repair as necessary. using a voltmeter measure the 5 volt supply circuit to the map sensor. is the voltage above 5.2 Volts?
yes. repair the 5 volt supply for short to power(i.e you have 12V touching the 5v wire somewhere)
No go to 2
2. wiggle map sensor connector any change in map sensor supply voltage?
Yes. repair harness and connector
No. go to 3
3. Inspect entire harness for damage and loose connections. Any change?
Yes Repair harness
No replace ECM
O.T
Sep 6, 2007 06:10 PM
Gene007
Feb 11, 2007 07:07 AM
Terraizer
Dec 14, 2005 03:56 PM
Lrdchaos
Sep 14, 2005 07:01 AM
CTD NUT
Apr 5, 2005 04:45 PM
