code 0500
Old 03-18-2004, 11:33 AM
Lrdchaos's Avatar
code 0500
I checked my truck today and it flashed code 0500, does anyone know what it means?
Old 03-18-2004, 11:46 AM
DieselDaze's Avatar
Check out the Codes listed in the FAQ section:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
Rich
Old 03-18-2004, 11:51 AM
Lrdchaos's Avatar
What causes that to trip the code? Sorry for all the questions I'm new to all this
Old 03-18-2004, 11:58 AM
DieselDaze's Avatar
I can only guess the obvious on this one. I'll have to pass a better answer on to the more knowledgeable.
Sorry.
Rich
Old 03-18-2004, 07:40 PM
phox_mulder's Avatar
Usually the sensor dying causes the code.
If your speedometer is working, and no ABS light flashing then the sensor must be good.
Sometimes spinning the tires will throw the code, maybe a little water in the sensor?
The only time I've seen that code on my truck is when I had a bad installation of my truespeed.
You splice the unit into the wire from the sensor to the ABS module, and the connection came apart.
Reconnected, with solder this time , and haven't seen the code since.
phox
Old 03-18-2004, 10:00 PM
Dr. Evil's Avatar
I had the same code not long ago - I suspect it was from spinning my tires on ice or from jamming hard on the brakes. It went away after I disconnected the batteries (allow at least an hour with batteries disconnected).
The sensor is on the top of the rear diff.....you may need to pull it, clean it with contact or brake cleaner and reinstall it if the battery trick doesnt work for ya.
LongBlackRam
01-08-2009 07:58 PM
1BAD4X4
12-19-2007 08:08 PM
ksnappy
02-03-2007 02:22 PM
Gambino-01
04-08-2006 11:42 AM
scottrod
11-02-2002 05:12 PM
Quick Reply: code 0500
