Clutch or Transmission?
Old 11-20-2003, 06:25 PM
Watch This's Avatar
My buddies truck went down the other night, we thought that the clutch had gone out since it has the stock clutch in it and it runs pretty good...lots of slipping..well anyways got it home and the clutch disengages so you can start it up and with the transmission in neutral it brings the rpms down and will not move at all when you let out on the clutch but is fine when the clutch is pushed all the way in.
What do you think?
thanks
Old 11-20-2003, 08:18 PM
RCW
RCW's Avatar
Re:Clutch or Transmission?
I would look for a shift fork failure that has allowed the transmission to engage two gears at one time. It is a fairly common issue with NV4500 5 speeds that are either power shifted or the gears slammed around drag racing. If it is a NV5600 6 speed, look for a crack in the case, just above the PTO plate. That is what they do, and then bind the mainshaft and lock-up. The cause is the same, fast shifting.
Old 11-21-2003, 11:53 AM
dodgeman01's Avatar
Kinda the same thing happend to a friend of mine but his main shaft snapped. No not the imput shaft the main shaft with the gears on it. cost was 1800 to fix. it took out 3rd and 4th gear in one little pop. No bang or snap just poped out of gear.
DM01
Old 11-21-2003, 05:38 PM
Watch This's Avatar
its a 97 and has the nv4500 in it....i think the clutch is working and the transmission is in a bind.....he does shift fast sometimes.... :
thanks guys
Dauntless
15
08-30-2016 08:37 PM
Derek Crowl
08-20-2013 10:43 PM
Bigdaddystroker
08-08-2007 01:02 AM
1ST GEN.
08-05-2005 10:29 PM
Haulin_in_Dixie
02-23-2003 08:08 PM
Quick Reply: Clutch or Transmission?
