clutch problems
Old Jul 3, 2009 | 08:21 PM
Coalfire's Avatar
clutch problems
Hey guys I'm out of town and having some issues. I Was in traffic earlier Waiting at a light with my clutch pushed in and after some time it felt like the clutch started engaging and lost all pedal feel and the truck started easing forward. I shut it off right them and started it up no problem. Try it a more safer spot did it again. It doesn't always do it but I think I glazed my clutch cause I here some chatter now. Oh yeah I got an 01 model with a six speed in it.What do you all think it is? thanks.
Old Jul 3, 2009 | 09:20 PM
JFlory's Avatar
Sounds like your hydros are failing.
Old Jul 3, 2009 | 09:33 PM
clops79's Avatar
need new clutch master cyl because of internal leaking
Old Jul 3, 2009 | 10:44 PM
dott's Avatar
X2. most likely it's letting the clutch out slowly and starting to engage.
Old Jul 3, 2009 | 10:49 PM
JFlory's Avatar
Can you even buy just the master cylinder for the hydraulics? I thought you had to buy the whole deal, because it was a closed system with no bleeder screw.
Old Jul 4, 2009 | 12:46 PM
Coalfire's Avatar
I checked the master cylinder ressy and there seems to be no fluid loss.
Old Jul 4, 2009 | 01:10 PM
JFlory's Avatar
You just need new hydraulics. It is all one system that doesn't have anything to do with your master cylinder. The hydros have their own little resiviour on the fire wall. The line goes to the clutch and assembly, then another line goes down to the actual slave cylinder at the tranny. Agian, it is all one unit and usually cost around $200-$250. Install is a pain, but can be done in the driveway with minumal tools. All you really need is a 10mm socket for the resiviour and a 13mm wrench for the nuts on the slave. Removing the clutch assemle part is the worst of it. there is a certian amount of push in and turn, then it releases. That is after disconnecting the one wire connection and pin that holds it the the pedal.
Thread all the stuff up and out of the engine compartment. Take note of how you did this. When installing the new unit, there is really only one way it can go in. It is a cobled up mess of lines and wires.
Hope this helps. Good luck.
Old Jul 4, 2009 | 02:48 PM
johnyb59's Avatar
you can buy just the master cylinder but its hard to tell which one has the internal leak.
Old Jul 4, 2009 | 02:49 PM
johnh's Avatar
sounds like the clutch master cylinder is leaking internally
you can buy the mc only from http://www.autopartswarehouse.com/se...er,brand:Sachs)
Old Jul 4, 2009 | 06:30 PM
mad bomber's Avatar
Youy lost the clutch hydrolicks. South bends sells a great one compared to stock ones. I was in this boat last summer
Old Jul 4, 2009 | 08:30 PM
Coalfire's Avatar
thanks guys I appreaciate it.
Old Jul 6, 2009 | 08:30 PM
dott's Avatar
When the clutch master cylinder leaks, it's internally bypassing the piston, so you won't notice a leak or fluid loss.
DJ Turbo.
Oct 13, 2011 09:11 PM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
