Clutch problems
Old 09-02-2008, 08:27 AM
johnyb59's Avatar
Clutch problems
I was out this weekend going for a cruise, came up to a stop sign, pushed the clutch in to downshift and I could not get it out of gear. I banged it out of gear and tried to put it back in gear but no clutch pedal I replaced the clutch master cylinder yesterday and with no luck it still didnt work. So I have a slave cylinder on the way. Does this sound like the right parts to fix the problem? I really hope its not something to do with the clutch itself, it only has about 1500 miles. P.S. How do you bleed this sytem. Why do we not have bleeders?
Old 09-02-2008, 09:27 PM
dozer12216's Avatar
First mistake was not buying as assembly. You always chose wrong component. The factory and Southbend assemblies are about same price with Dodge kit slighty easier to install without bleeding worries.
Anyway wou are stuck with component replace. Push fluid out as you make connection between two lines.
DJ Turbo.
10-13-2011 09:11 PM
Fishbait
06-06-2006 12:34 PM
mbmrang
01-21-2006 12:49 PM
kwhite4
05-09-2005 03:22 PM
Quick Reply: Clutch problems
