Clutch problem
Old 09-03-2007, 09:50 AM
bluechrome's Avatar
Clutch problem
Well I pulled last night And now something wierd is going on. I tried to pull in 4th low as for that is what worked well the last time I pulled. This track was a different animal (VERY STICKY)!! The truck just did not have enough power.
So, now my clutch is making a grinding sound when fully engaged (pedal all the way pushed in). I adjusted the clutch all the way in and the noise is not as bad. I did slip it to about 35ft but the truck didn't have the power or momentum to keep it going. When I drove home Shifting is only a little thougher and it is still grabbing very well. Please help
Old 09-03-2007, 10:20 AM
PourinDiesel's Avatar
How many miles on the clutch?
I'll pm you phone number if you have any questions I can help with....Explaining things over the net can be difficult...
Old 09-03-2007, 10:23 AM
bluechrome's Avatar
I only have 2000 miles on it and this is the second pull on it. Your advise would be great
Old 09-07-2007, 03:23 PM
bluechrome's Avatar
wELL I JUST DON'T GET IT AND i GUESS KNOW ONE ELSE DOES EITHER . Talked to south bend and they said don't worry about it. I'm fine with that but this noise is nasty and I can't really ignore it. I haft to push the clutch in all the way to start the and th grinding is loud. What could this be? I there something bent? I have the slave adjusted for the shortest throw and it is kinda hard to drive like that. I need some help? The best way I can put it is its like it is over engaging the clutch. Other than that I am lost
Peter told me to jerk the tranny .................. again
Old 09-07-2007, 03:54 PM
05CTDN8's Avatar
Could be something like the throw-out bearing or maybe you tore part of the friction surface off...unlikely, but who knows,
Old 09-08-2007, 01:02 AM
dieselfreak21's Avatar
Sounds like your screwed up the hub on the disk(s). I had the same thing on mine at 300mi. Mine was a manufacturing defect. I would step on the clutch and it would sound like you were grinding gears and wouldn't shift and wouldn't really disengage. They told me not to worry about to but i didn't talk to peter as he was taking a well deserved vacation. I went back to my installer and he knew something was wrong and found it. I wouldn't think anything you did caused with based on what you described but SBC will have to decied that they are the experts.
Old 09-08-2007, 01:08 AM
I would pull the tranny and inspect the clutch for any issues.
It could have a bent disc or something to that effect or maybe even a collapsed finger or springs.
Keep us posted...
Old 09-08-2007, 10:39 AM
bluechrome's Avatar
Well I'm pullin the tranny next weekend. Peter wants to get me into a sprung hub. says the solid are just brutal on everything [I]'ll take pics. He also thinks that something could be wrong with the floater plate. but we'll see.
I guess when yuo sometimes play you sometimes pay. I'll let ya know.
He alos said don't worry about it he'll take car of me
Old 09-18-2007, 09:42 PM
bluechrome's Avatar
Pulled the tranny Tonight (3rd time this year)! I'm not very happy. All the plates look like they got very hot. In both friction disk It looks like somebody dragged a pin across the buttons. The flywheel Has a bunch of hot spots on it. I just don't get it. Also there are signs of wear / play in the hubs. I don't think I slipped the clutch that bad while pullin for it to look like this but I could be wrong."Any clutch will get super hot while sled pullin." The friction disks Are not glazed at all. I'm going to talk with peter on thursday to get to the bottom of this. I hope he can help me out because i am very broke right now.
WACTD
07-25-2006 11:41 AM
Fishbait
06-06-2006 12:34 PM
mbmrang
01-21-2006 12:49 PM
kwhite4
05-09-2005 03:22 PM
Quick Reply: Clutch problem
