Clutch is gone
Clutch is gone
Hello All,
My clutch went out this morning at 40701 miles. sigh
Is there a good shop in SLC I can take it?
I aslo want to call around and see what the prices are to put in a South Bend in. Do you know some shops for this swap?
I am wondering if since the tranny is out, if I should get the taller 6th gear in the later model.
I don't remember what the differnt number is but I know I have the first generation G56 that has the .74 in it instead of the .79. Those numbers could be reversed. But it gains you something like 200 RPM in 6th.
https://www.dieseltruckresource.com/...&highlight=.74
I am going to go with south bend. Now which one? I will eventually get a smarty jr. But that is it. Which version of south bend should I get? I think the con ofe will be over kill. Only looking for opinions.
none, same driving as my 94 that has the original clutch and has 171,000 miles on it.
I pull a 5er about 10 times a year and 6000lb boat about 20 times. It comutes to work.
But thanks for your constructive comments on the thead.
Hello All,
I assume you truck is stock. Put on a set of 35's and reap the rewards on fuel mileage and lower interstate towing RPM's. I cant imagine the cost to change out 6th gear. My truck currently has 170,000 with stock clutch and mild power adders. Towed my 6k pound boat from coast to coast about 4 months ago with no issues. I can slip the clutch at will, but I've learned to drive it so it doesn't slip. My next upgrade will be a Southbend clutch , but still not sure which one. Good luck. BTW, can you make it through gaurdsman's pass yet? It's a beautiful drive....
TAMU
05-27-2009 06:34 PM
TAMU
04-27-2009 11:26 AM
