Clutch & Brake
Old 03-03-2004, 09:45 PM
Dr. Evil's Avatar
Clutch & Brake Pedals
This is for the guys with manual trannys....how much height difference is there between your clutch and brake pedals??? Can some of you guys check for me?? On my truck (6 speed) the brake is probably an inch and a half lower.....dealer says that is normal.....i dont think so.
I have recently noticed there is a big difference....just not sure it was there before....if some of you guys could check your pedals out Id really appreciate it....thanks.
Old 03-04-2004, 04:17 PM
Hey Doc, this may not apply to the newer trucks, but on my antique the plastic bushing inside the pushrod had disintegrated, allowing metal to metal contact between the pushrod and the pedal. The pushrod had worn oval and the pin on the side of the pedal was halfway gone. Crawl under your dash and make sure something similar hasn't happened to you. My low buck fix was to cut the end off the pushrod, thread the rod, and use a rod end (AKA heim joint) bolted to the pedal. Allows me to set the pedal where I want it, too.
Old 03-04-2004, 04:38 PM
scuzman00's Avatar
Hey Doc,
Just went out and measured mine and the clutch pedal is exactly 1" higher than the brake pedal..... Gues you got a keeper as far as the service guy you asked question to. Since our clutches are hydraulic, the wear should not be a factor on pedal height.
Gary
Old 03-04-2004, 09:43 PM
fireram's Avatar
My 99 mesures the same, brake pedal is 1" lower than the clutch...
Old 03-04-2004, 10:15 PM
Dr. Evil's Avatar
Thanks a TON guys.....if it wasnt for the stoopid girlfriend using my truck I probably would have never noticed the difference....
oldiron27
09-06-2012 11:26 AM
Ridiculous
05-17-2007 07:28 PM
Mark Hodowanec
02-26-2006 08:35 PM
Quick Reply: Clutch & Brake
