Clutch and Shop Advice in Louisville, KY
Old 05-06-2011, 09:50 AM
06BigHornCTD's Avatar
Just noticed my clutch slipping for the first time yesterday getting on the interstate . . . so i'm starting to look at replacement clutches. Obviously the dual-mass flywheel has to go. I'll probably follow the crowd here and go with South Bend for a new clutch/flywheel, but I'm looking at Valair also. My biggest question at this point is should I stick with a single or jump to dual disk? I run a Smarty Jr. and have no intentions of adding anymore power, and I do not tow often or heavy. My truck is a dd for sure. The only reason that I was thinking dual is because in my head, it makes sense that it would last longer since there is more material to go around. Is my thinking correct? I don't mind paying a little more if it is going to last longer or be a better product.
Second question is, is a good shop in or near Louisville that can install a clutch and do it right the first time?
Thanks.
bigfoot
05-09-2011 08:48 PM
91rangerturbo
KYDTR #41
03-31-2009 02:38 PM
91rangerturbo
KYDTR #41
05-05-2008 12:31 PM
sherod
04-17-2005 08:18 AM
Quick Reply: Clutch and Shop Advice in Louisville, KY
