Clutch adjustment?
Old 05-04-2007, 08:40 PM
normht's Avatar
Clutch adjustment?
Just installed a new clutch,pressure plate,throughout bearing,pilot bearing ,clutch arm stud,master cyl and slave cyl and had the flywheel resurfaced. after everything is back togeather i cant get the clutch to disengage all the way.IE the thing grinds when i try to put it in gear.It acted as if the slave cyl rod was to short .Fabricated a rod a little longer and now i can get it in gear ok but the clutch slips a little. whats the trick to setting this thing up?
Old 05-05-2007, 12:24 PM
arroyojim's Avatar
"A new clutch will require pretty close to the full travel of the clutch pedal to disengage. Sometimes it is a simple as removing an extra floor mat that the pedal bottoms against. Any internal wear in the hydraulic system or external wear in the under dash components, clutch fork, and/or fork pivot ball can cause inadequate disengagement. The solution is to replace or repair the guilty parts."
from http://quad4x4.com/NV4500FAQ.htm#what
not sure if this will help, but here it is...
Old 05-05-2007, 05:38 PM
normht's Avatar
Arroyojim, Thanks for the info.It,s at the dodge dealer right now.After asking around I found that the flywheel was probably cut down too much.I,ll find out monday what the problem is for sure.
Old 05-06-2007, 12:02 PM
lews930's Avatar
check your clutch pedal pivot pin, mine is worn and wobbles inside the m/c rod
lewis
Old 05-07-2007, 09:31 PM
normht's Avatar
Dealer called today and said the clutch disc had been installed backward.A $1400.00 lesson.
BCB
03-06-2006 04:20 PM
FORDNOMORE
12-31-2005 10:09 PM
edwinsmith
03-19-2005 08:45 PM
Altaboy
11-03-2003 01:19 PM
Quick Reply: Clutch adjustment?
