club cab doors
club cab doors
Anyone else having problems with their club cab door sticking? My passenger side door quit opening last year and I haven't had time to look into it. Yesterday the driver's side door of my '99 Ram stuck.
The bottom latches need to be oiled somewhat regularly, or they will stick. Opening the door panel up once in a few years to grease the linkage inside is also very helpful.
EDIT: I just read the post again, is it a 4 door or 2 door extended cab? I posted about the rear doors, but if its the front doors I had a slight problem with my drivers door sticking from the hinge being worn out, so it would rest heavy on the latch. Had to pop the pins in the front to change the brass bushings out. It also wore out the nylon slider on the latch a bit, all is well with new bushings and re-alignment of the door. Good luck.
OUTDOORSMAN
Apr 22, 2010 01:19 PM
greasemonki
Dec 21, 2005 06:14 AM
