climate controls problems
Old Jan 18, 2008 | 12:38 PM
hammerhead's Avatar
I have a problem with my climate controls on my truck and need some ideas. I had the dealership check it and they put a new head unit in the truck but that failed to fix the problem. What it is doing is it won't move from vents to floor or to defrost. I can't tell you how aggravating this is. The dealership wants $500 labor just to tear into the dash and see if there is something they can find.
Any ideas are welcome and, If anyone else has had a similar problem and found a solution that would be great.
Thanks in advance,
Eddie
Old Jan 18, 2008 | 05:32 PM
JWillms81's Avatar
Have the same problem your having but mine comes and goes, for the most part its broken but evey now and then I can get it to change to defrost or floor. Here is a post with some part numbers and TSB numbers along with a link to step by step directions on replacing the part. If you search user Ratlratl has a good write up with pictures on how to take the dash apart to get to the part that needs changing. I have been lazy and havent done anything about mine, maybe when it warms up a little Ill get around to doing it.
LINK
Hope it helps
JW
spitfire9137
Aug 2, 2008 11:43 PM
Vinceg99
Feb 12, 2007 09:31 PM
SolarYellow05
Jun 22, 2006 04:55 PM
grizzly660fan
Jan 2, 2004 10:02 AM
