Checking Codes
Old Mar 7, 2005 | 10:08 PM
snookinaround's Avatar
Checking Codes
dumb i know, but how do you check for codes.
Old Mar 8, 2005 | 12:39 AM
xbowtie's Avatar
If its a 3rd generation truck, try turning ignition on with out starting three time, watch your trip meter for the codes. If there are none, it will simply read done.
Old Mar 10, 2005 | 09:48 PM
04 Diesel's Avatar
Hold your trip button down, turn key on but dont start moter. watch for codes. I found out by accident tonight.
Old Mar 11, 2005 | 01:45 PM
thanks
Old Mar 12, 2005 | 10:41 PM
04 Diesel's Avatar
Old Mar 14, 2005 | 07:23 PM
djbikeman's Avatar
hours vs codes
To check codes you turn the key to the on position quickly 3 times, then the codes appear. If there are none, it says "done". (do not need to actually start)
04 diesel -- Based on what you did, you should have been viewing the engine hours. To view engine hours you hold the trip button down and turn the key to on position and hold for 6 seconds. If you were viewing codes, it will scroll through the codes if you have any and then say "done".
I could very well be wrong, but I did a search and I have checked engine codes a few times, especially after forgetting to plug in the MAP and getting the check engine light.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tacohat
Jul 17, 2006 02:27 PM
DarrellB
Sep 6, 2003 04:49 PM
