how to check if fuel heater is working
The best way would be to find someone with a dc clampmeter to check the ampload, otherwise you can check the ohm reading by unplugging the wire connector and making sure that you get a resistance reading, then check for voltage on the wiring harness supplying power to it. I think I read somewhere that it has to below 40 deg. for the fuel heater to turn on, but someone that knows a little more about these can correct me.
Fuel heater should operate when the fuel is between 45±8, and 75±8 (IIRC)..
Other than resistance or ammeter I am not sure. Maybe an IR gun on the inlet and outlet of the fuel canister when the fuel is known to be below 45*F
How do you know all this stuff??? Must have a mind like a steel trap, and a perfect memory!! Glad you're on this forum!!!! THANKS!!!
Sleigher
05-04-2017 02:12 PM
Crabjoe
12-27-2005 07:24 PM
tool
04-11-2004 05:51 PM
