check engine
Old Mar 19, 2005 | 09:03 AM
timeagain's Avatar
Question check engine
Hi guys, my check engine light stays on all the time, How do you get the codes from a 98, 12 valve , I tryed to cycle the ing. switch 3 times and nothing.
Old Mar 19, 2005 | 09:10 AM
Shovelhead's Avatar
Administrator / Scooter Bum
The key-on, key-off trick only works on 2000 model years and up.
The code readers from your local parts store will access some codes but not all.
It takes a DRB tool (like the one the dealer uses) to acess and clear all codes.
Old Mar 19, 2005 | 09:18 AM
timeagain's Avatar
Thanks guys, I gess I'll have to see a dealer for my light.
Old Mar 19, 2005 | 11:56 AM
infidel's Avatar
Actually the key off/on trick works on all 2nd gen trucks except '98&'99
Instead of reading the numbers on pre '98 you have to count the number of times the check engine light flashes.
'98&'99 require a code reader.
You're still out of luck but just to clarify for others.
Autozone will read your codes for free.
Old Mar 19, 2005 | 12:19 PM
Shovelhead's Avatar
Infidel is correct (as usual) about the prior years and counting the flashes.
My experience with Autozone was they're using the off-the-shelf cheapie code reader that showed no codes on my 99 when I was having tranny troubles.
Using the DRB at my local dealer, the techs pulled 3 codes that Autozone couldn't see.
Old Mar 22, 2005 | 12:05 PM
FrdRdnk's Avatar
Just to add some more to the mix, disconnecting the battery should clear the codes but obviously won't help as to what's going on.
Adam3291
May 2, 2008 10:08 PM
buddy26
Feb 15, 2008 12:17 PM
alltimelow1
Apr 6, 2005 07:28 PM
Gary C
Mar 15, 2004 02:53 PM
