check engine light
Old 12-17-2006, 01:31 AM
loch's Avatar
check engine light
My sisters 93 5 speed , the check engine light is on, this is after an alternator and a new computer from dodge. The light didnt immediatly come on, took 3 days after computer. any ideas ?
Old 12-17-2006, 09:35 AM
Do the key cycle trick that's in the sticky to find what code you have, that'll give us something to work with.
Old 12-18-2006, 05:57 PM
loch's Avatar
Dave I checked the codes and I got a 35 and companion code 55. 35 wasnt in the list in the sticky, but in paper work that came with comp it says."
35=Idle switch shorted or open circuit
any ideas now ?
Old 12-18-2006, 05:58 PM
Is this a diesel?
Old 12-18-2006, 06:39 PM
loch's Avatar
93 5 speed dually, CTD, there are several codes in the paper work that are differant, i can scan them tomorrow and post it. when i tested codes was odd, i actually got this,, / is flash ///, ////, /, /////, ///// now since they display in two digit codes the single flash has to be part of the 34 ie 35 and 55. and the 35 is listed in my paper,
Old 12-18-2006, 06:42 PM
That looks like 34 and 15 to me.
Old 12-18-2006, 06:52 PM
loch's Avatar
But they flash inswquencial order, as in 6 is before 7 and after 5, if its 34 and 15, 15 cant come last can it ?
Old 12-18-2006, 08:51 PM
dodgenstein's Avatar
The 55 makes sense, it signals end of code. I can't find any trouble code 35 that applies to a diesel. A 34 is a speed control solenoid code.
Info from www.minimopar.net
Old 12-19-2006, 12:19 AM
loch's Avatar
Dave if it helps, i posted the codes that came with vomputer in my gallery.
buddy26
02-15-2008 12:17 PM
choppers555
10-16-2007 12:29 PM
alltimelow1
04-06-2005 07:28 PM
Fillerupsonny
10-09-2002 06:01 PM
Quick Reply: check engine light
