Check engine light/loss of power
Old 11-24-2004, 11:21 PM
poorboy cmns@u's Avatar
Driving tonight in 32*F temp w/snow blowing, & the MIL light (check engine light) came on and stayed on. I stopped, shut the truck off, checked for codes (showed none), and restarted the engine. The light continued to stay on. I continued down the road, and the engine progressively lost power, to the point that I began to think I would be walking home. Any ideas on this problem? Will a plugged fuel filter cause the check engine light to come on?
Old 11-25-2004, 12:31 AM
RadRam's Avatar
If it was snowing - I would guess - plugged air filter.
My stock filter plugged while driving in a snow storm - major power loss - pyro temps thru the roof.
Old 11-25-2004, 07:07 AM
nord's Avatar
First rule of a diesel vehicle with a problem... CHANGE FILTERS.
Second and third rule... CHANGE FILTERS.
Just a guess, but gelled fuel can cause the problem. Obviously a plugged air cleaner will too. I'd be most likely to suspect lack of fuel due to gelling or a plugged filter. Did you happen to check for excess water?
RHC
08-12-2019 03:32 PM
Viesel
22
03-18-2005 08:04 PM
PK
11-05-2004 10:46 PM
Ram4Play
06-17-2004 05:36 PM
Quick Reply: Check engine light/loss of power
