Check engine light and P0118 code, help please!
Old Sep 22, 2007 | 12:05 AM
CrooksB's Avatar
I just finished installing a Quadzilla Commander. Took the truck for a test drive and noticed the check engine light would'nt go off. The next thing I noticed was the boost gauge was'nt registering boost pressure. When I got back home I checked to see if there were any codes and it was throwing P0118 code. Can someone tell me what the P0118 code is and why it is'nt registering boost?
Old Sep 22, 2007 | 12:11 AM
Luvnacumns's Avatar
P0118 Engine Coolant Temperature Sensor High
Did you forget to plug the sensor back in.. I did when I installed mine...
Old Sep 22, 2007 | 12:16 AM
Billm2004's Avatar
+1...Coolant temp. sensor. things that can cause bad sensor readings can be a disconnected sensor, a low coolant level in the cooling system, a thermostat that is stuck open or shut, or a thermostat that has the wrong temperature rating for the engine.
Old Sep 22, 2007 | 12:21 AM
53 willys's Avatar
you either forgot to plug the coolant temp sensor back in or the sensor is bad........
Old Sep 22, 2007 | 12:39 AM
CrooksB's Avatar
Luvnacumns,
I did a search for P0118 and read a post you wrote in February, and I think I left the temp. sensor unplugged at some point with the key in the on position by accident. I'm still unsure of why the boost pressure is not registering though.
Old Sep 22, 2007 | 01:28 AM
qzilla's Avatar
1.) Make sure you are on the correct wire. You could be on the Ground. Make sure you get it on Pin D. IF the latch is facing you and the wires are pointing toward you Pin D will be on the far right side.
2.) Make sure you selected the proper vehicle
3.) Make sure you are giving enough throttle to make some boost. If you are putzing around or at idle boost will be ZERO.
Old Sep 22, 2007 | 09:08 AM
Luvnacumns's Avatar
Originally Posted by CrooksB
Luvnacumns,
Yep I did the same thing started the truck and ran it But after a while it went out after I plugged it back in... Also Quad is correct you won't see any boost while ideling or slowly moving.. Just check his suggestions and well go from there..
Old Sep 25, 2007 | 02:14 PM
CrooksB's Avatar
Still no boost reading! I double checked the settings and wiretap, then took the truck for another test dive. This time I spooled the turbo, and hit around 75 - 80 mph, still nothing.
Old Sep 25, 2007 | 03:52 PM
QPTRR's Avatar
Did you check to make sure that the spade terminal went into the tap instead of getting pushed to one side and not making contact. I have seen that happen a few times.
Old Sep 25, 2007 | 08:34 PM
CrooksB's Avatar
QPTRR,
That was it! I pulled the terminal off of the tap two or three times & didn't even notice that the spade was slightly bent. Thanks to everyone for all the input.
Old Sep 25, 2007 | 11:01 PM
qzilla's Avatar
Glad you got it fixed!
Ok, one thing I want to say is that the one reason we always ask so many questions and go over so many stupid things is because of the testing process we go through before our products are shipped out.
We had a distributor in our office last week and he got to see the testing process first hand and his jaw dropped! We literally hook everything up like it was on a truck, run it through a complete simulations including button pushes, changing temperatures, defueling, warnings, power levels ect.
There is no good reason one goes out of our facility and does not work. Our test process, especially on the Commander is crazy. So once they pass all this it is hard to believe something does not work and that is why we ask all these annoying questions instead of just shipping another one out. It is not because we don't want to, it is because we should not have to!
Anyhow, glad you got it going your way!
hot tempered
May 12, 2012 10:04 PM
Luvnacumns
Feb 20, 2007 07:18 PM
tslewisz
0
Jan 15, 2007 08:51 AM
tractorengine
Mar 2, 2006 03:49 PM
Strick
Dec 20, 2004 08:20 AM
