PDA
View Full Version : Cheap Mods on 04 HO?
gdh11
11-13-2003, 06:00 AM
Just got a new 04 Dually 4x4 and want to get under the hood to play. Can anyone tell me what the simple tricks are for the HO motors that we can do ourselves for little or no $$. I am still reeling from the downpayment. I know on the PSDs if you pull and plug the wastegate hose it ran cooler (EGTS) and the turbo spun up faster. Also I saw a post where someone mentioned a silencer ring? Does that increase performance or just make more noise? Anything else that I missed? AFE and TAG are on the way and am taking a long trip soon and want to do all that I can before I go. ;D
The Boss Hog
11-13-2003, 06:23 AM
gdh11,
First, welcome aboard. Second, the best performance mod you can do right now is to put about 10k miles on it. Mine runs considerably better now (~28k) than it did when new.
The Boss Hog
(Survived another summer in Florida 8) )
cem
11-13-2003, 09:33 AM
Agreed! I have almost 6k miles on mine now and it seems to be getting stronger all the time. Fuel mileage is going up each time I fill up also. ;D
Chris
Jack Thorpe
11-13-2003, 09:52 AM
My fuel mileage hasn't been great with this truck so far. The computer is telling me I'm averaging about 15 mpg. The old truck in the same situation would be doing about 19-20. I'm sure it's partly because it's new, and a dually, and 4wd etc.
Carnage
11-13-2003, 10:44 AM
I got 10,500 miles and still get 16 mpg with an unloaded truck! :'(
I did put the Bully Dog box in earlier this week and made a huge difference in power. That whole thing cost me $1,000 including the gauges.
RamDan03
11-13-2003, 10:53 AM
At 10K miles I am now getting 18-18.5 MPG unloaded. When my rig was brand new it was more like 17-17.4
cfm3110
11-13-2003, 11:57 AM
Ok....same question, but my truck has 26k on it, what are some cheap tricksthat will hold me over till i wanna buy a box???
gdh11
11-13-2003, 12:18 PM
I have less than 2K on mine and will unhook the wastegate and install an AFE and TAG shortly. There is a vendor that just let me know that the 03 exhaust systems will fit an 04 swo that's next. I'll let you all know how it works.
Agades
11-13-2003, 01:36 PM
if you disable the wastegate , wont you set overboost codes?
I know you would on a 2nd gen without using a boost fooler
gdh11
11-14-2003, 05:34 AM
The last time I did it I had to put a BOV on the line to the wastegate to prevent overboost codes from being set. Does anyone know what pressure the DC computer sets the code for overboost? Normally it is 19-20 PSI.
Push Rod
11-14-2003, 08:41 AM
The 03 and 04 Cummins have a bit of a unique program in them for overboost. We haven't set a check engine light yet, however without a fooler, each time you overfuel, the ECM remembers and will keep cutting fuel back until the boost remains in the 24 - 26 range. The effect is so gradual, that you may not even notice the power loss until you hook up a trailer or do something that requires more power.
Rod
Agades
11-14-2003, 10:37 AM
Ah so we have a "smart ecm"
whats next?
uplink to government satelites to control power output in each state [eyecrazy]
