Changing Rear End in FL 60
Old 12-08-2003, 04:40 PM
turfquip's Avatar
At 65 MPH, my engine is turning 2900 RPM's. That affects fuel mileage in a big way. I'd like to be turning around 2200 - 2400. Now here's the question:
My Rockwell rear axle is a 433. How big a job would it be to change it to a 355? Would axles need to be changed as well? I've got more than enough low end right now. I start the truck in 2nd from stop. First is low - low.
More importantly, would this change produce the desired RPM and fuel savings?
Thank You!
Old 12-08-2003, 06:34 PM
4x4
4x4's Avatar
Re:Changing Rear End in FL 60
The 3.55 will help a lot, especially if you have overdrive. Unless you've done it before or are an extremely good mechanic you should have someone change them for you. The axle shafts will not need to be changed, and your mileage should increase dramatically. Good luck.
4x4
Old 12-08-2003, 07:43 PM
turfquip's Avatar
Thanks,
I have a mechanic who is capable. There is no way I would even attempt it.
Do you believe I would see a reduction in RPM"s the way I hope to or maybe even better? No overdrive in this truck, it's a five speed.
Old 12-08-2003, 08:00 PM
Rare1's Avatar
I guess that fifth gear is overdrive. Your owner's manual should have that info.
By ratio, your RPM with 3.55 gears at 65 MPH would be 2377. However, if you pull your 5er at its max safe speed stated in the manual, 55 MPH, your RPM with present gearing would be 2454. That would maintain the pulling power you now enjoy and also produce higher milage.
It's not only your RPM spoiling your milage, but also your speed. Between 2454 RPM and 2900 RPM there's no increase in torque but a large increase in horsepower produced. That increase in horsepower is needed to overcome the increased air resistance of pushing your rig at 65 instead of 55. Making more horsepower requires more fuel, but you knew that.
Have a look at this http://www.rversonline.org/fueleconomy.htm
Especially read the first sentence after the graph. I know this is not your or my rig in the study, but it does apply somewhat to all of us.
DLittle
04-13-2010 08:52 AM
doorguy
06-08-2007 06:19 AM
Katfish
03-14-2005 07:04 PM
supr
15
08-04-2004 03:33 PM
royta
07-13-2004 06:54 PM
Quick Reply: Changing Rear End in FL 60
