Changing Piston Rings In Truck
Old 02-18-2010, 11:55 AM
Rollin'_Coal's Avatar
Question Changing Piston Rings In Truck
Hey guys, I'm looking to change the piston rings in an 07 5.9. I am unable to do it myself due to a broken ankle and being on crutches so i'd like to know if it can be done in the truck? The shop i had look at it says that it is over 30 hours of labor and they have to pull the engine. I heard awhile back that having head studs will ease the removal of the head in the truck? Something like the long headbolts are hard to get out but the studs only stick up a little, so it just lifts out? Also for removing the oil pan i've been reading that by undoing a motor mount and lifting a little, you can get the pan out? so, Which motor mount? I want to be able to give the shop some ideas as they are willing to do it in the truck but dont know how. Thanks in advance.
Old 02-18-2010, 12:23 PM
SmokeN 12 ValvE's Avatar
I would think it would have to be pulled. I am rebuilding my 12v now and could not imagine trying to put new rings on while it is in the truck.
Old 02-18-2010, 12:43 PM
cbrahs's Avatar
you don't have to pull the motor. just like doing an inframe on a big rig. yank the head, lift the motor a bit (on ours, not a big rig of course) and drop the pan. not a big deal. if they say they have to yank the motor, go to another shop.
btw- both motor mounts and lift motor a bit to remove pan, remove pan and lowe motor back down onto the mounts.
studs have nothing to do with it. no difference in length to worry about it. back cylinders have a rubber plug on the firewall to remove the bolts.
Old 02-18-2010, 12:44 PM
Excellent, Thanks guys. I'll try another shop.
Old 02-18-2010, 12:51 PM
cbrahs's Avatar
as soon as I get to a real computer, i will log onto alldata and get you actual book time so you don't get the shaft
Old 02-18-2010, 06:26 PM
Dieselhed's Avatar
Cool. I'd like to know as well as this is next for me.
Old 02-18-2010, 08:51 PM
cbrahs's Avatar
here is the scoop
they always start out the book times with a single piston
1 piston set 20.6 hours (Includes: Remove Cylinder Top Ridge, Deglaze Cylinder Walls And Clean Carbon)
each additional ring set add .3 hours ( Includes: Remove Cylinder Top Ridge, Deglaze Cylinder Walls And Clean Carbon)
NOTE:
with skid plate add .3 hours
with 4x4 add 1.0 hours
R&R Piston, Pin or Connecting Rod, Add .2 hours (single piston) each additional add .1 hour or .8 hours for all 6 if done at one time
R&R connecting rod add .1 hours for each rod
ahire
13
10-17-2008 12:50 PM
BigErksG2
09-25-2008 06:43 PM
12VRoush
10-15-2007 08:00 PM
1320
03-08-2005 08:56 PM
Quick Reply: Changing Piston Rings In Truck
