Changing Manual Tranny Oil - Any Suggestions?
Old 12-28-2004, 12:35 AM
HighTen's Avatar
Question Changing Manual Tranny Oil - Any Suggestions?
I'm ready to change the oil in the transmission. I got some Redline MTL at the local Summit and some black Permatex also. I plan on taking the PTO cover off so I can wipe out any solid material in the bottom after the oil is drained.
So I guess after taking the PTO cover off, you can just scrape the old gasget material off and put some fresh Permatex on?
Thanks for any suggestions or wisdom.
Old 12-28-2004, 02:26 AM
nickleinonen's Avatar
yep... you can also grab the magnet in the bottom of the tranny and clean it up too... i used a razer on the transmission to scrape it clean and then some brake clean to make it non greasy... on the cover, i used a gasket grinding disc on a air sander, but a razor would do too... clean and non greasy makes it seal best for the gasket
Old 12-28-2004, 06:04 PM
HighTen's Avatar
Thanks for the tips.
I'm glad this fluid replacement job sounds pretty basic.
Old 12-28-2004, 11:29 PM
Nevada's Avatar
Take out the bottom PTO bolt first and let it drain.
H BROWN
49
08-01-2019 01:13 PM
georgboy
09-12-2008 04:51 PM
NM3500HD
22
01-07-2008 07:57 PM
ezdemon72
07-29-2005 10:05 AM
Palmetto_kid
06-28-2004 07:14 AM
Quick Reply: Changing Manual Tranny Oil - Any Suggestions?
