Changing injectors
Old 05-26-2010, 02:59 PM
fastlane's Avatar
Changing injectors
How hard is it? repair shops say unless you are a certified diesel tech don't even attempt to change an injector. I am an above average mechanic, and have an above average set of tools, no specialty diesel tools though. My #5 injector went out recently and cost $1200 to fix. I use this truck to pull a trailer ever day, it needs to be tip top. how hard can it be?
Old 05-26-2010, 03:12 PM
15 Digger's Avatar
You can do it. I saw a write up with pics of the job and I'm sure I could do it and I'm no mechanic. If you follow the service manual and torque specs you should be good if your above average. Don't let the shop take your money.
Old 05-26-2010, 04:18 PM
Diesel87's Avatar
It is not that hard. I did mine myself, and I'm like you an average do it yourself mechanic. I printed off the directions off Dynomite Diesel's website. Just follow the directions and you will be fine. The hardest part for me was prying the injectors out. I'm not sure if they make a special tool for this or not, but if not it's still not too bad. If you have any questions PM me.
Old 05-26-2010, 05:31 PM
jeffro mopar's Avatar
Dont sweat it its not bad at all i just replaced mine and it was my first time working on one .
Old 05-26-2010, 05:33 PM
OCMerrill's Avatar
http://www.cumminsforum.com/forum/3r...procedure.html
There is a pdf link there.
Old 05-28-2010, 06:24 PM
fastlane's Avatar
Thanks guys, I found industrial injections 50hp injectors for less than I paid for one, I will do it myself and also adjust the valves while I'm at it.
Old 05-28-2010, 07:18 PM
NickBeek's Avatar
There is a specific procedure to re-assemble the injector in the engine. Find the service manual and follow the procedure and all will be well.
Did you get and entire injector or just the nozzle? If the injector itself is bad a nozzle won't fix it.
Old 05-28-2010, 07:36 PM
fastlane's Avatar
haven't purchased anything yet, but it will be the whole injector. and i think the pdf OCMerril gave me was pretty in depth.
Old 03-02-2011, 06:49 AM
Mr.mean's Avatar
Diagnosing a bad injector
At about 50,000 I had two injectors blow the tips out , had them replaced under warranty. New they were bad because oil coming out of crank case vent. 215,000 had the same problem with oil coming out my crank case vent. Don't know any diesel mechanics locally, so I took it to the dealer. 1200.00 for #6 injector. The mechanic told me the tip was fine but fuel was leaking around an Oring. My question is how can you tell the injector is bad by just looking at it? Could'nt the mechanic have just changed out the Oring? Took the Dr. P box off and will probably leave it off. I have had it on the truck since day one.
Old 03-02-2011, 09:39 AM
DTR 1st Sergeant
soulezoo's Avatar
Pressure boxes do shorten injector life.
There is a special too that will remove the injector body from the head; however, I normally just use a simple pry bar under the hold down. It comes out quite easily.
Old 03-02-2011, 10:07 AM
Mr.mean's Avatar
Do I need to look for high fuel pressure anywhere while pulling injectors?
Old 03-02-2011, 01:07 PM
ARIZONACLASSIC's Avatar
Nope. Just don't try to replace your injectors with the truck running.
Old 03-02-2011, 07:02 PM
horsehelper's Avatar
Youtube the install and you can watch it there.
Old 03-02-2011, 08:52 PM
6.6lEater's Avatar
You will be ok. Just take your time and remember a torque wrench is your friend when its time to tighten things up.
Old 03-02-2011, 11:41 PM
12valvedutchy's Avatar
youll be alright. just stay organized and CLEAN! Im 19 and I changed all six of my injectors. Just take your time. Most of the write ups I have seen are pretty good. So you have a good start. The best tool I used was the engine barring tool to get the truck Top Dead Center (TDC) I ended up using an inverted screwdriver to pry the injectors out and it worked pretty nicely. They do make a tool to pull them out but it is very expensive. Goodluck!
KRB
05-20-2007 06:20 PM
BIGOKIE
07-21-2004 05:53 PM
Gene007
09-13-2003 01:07 AM
mcgyver01
11-21-2002 09:31 PM
Quick Reply: Changing injectors
