Change your brakes yet?
Old 12-10-2004, 02:10 PM
dodgedude361's Avatar
I just hit 42,000 miles and was thinking about looking at the brakes. Has anyone changed thiers out yet? at what milage?
Only 5-10 percent of that milage is towing. They still work, just not as good as when new.
Old 12-11-2004, 02:27 PM
Ram1's Avatar
I am still on the factory set with 94,000 on my 03. I tow all of the time also. I also run my PacBrake loaded & unloaded.
Old 12-11-2004, 04:45 PM
ok, thx for the heads up
Old 12-11-2004, 07:22 PM
falcondan9570's Avatar
I have heard the rotors are "press fit" onto the hubs... They turn the rotors on the vehicle...
Old 12-11-2004, 07:36 PM
TroyH's Avatar
I changed the pads and roters at 75000 roters slid right off not presed on
Old 12-11-2004, 09:52 PM
Bertram65's Avatar
What did the pads and rotors cost?
Old 12-12-2004, 06:14 PM
you CHANGED the rotors, or had them cut??
Old 12-12-2004, 07:03 PM
JHardwick's Avatar
everything is disposable these days
Old 12-13-2004, 05:19 PM
jelag's Avatar
I have an 04 with 97K on the clock.... we're just putting it back together after checking the brakes.... We tow with this truck 80% of the time and use the pacbrake all the time...
All the inside pads were at 40% or so... and all the outside pads were 55% or so... why the inside pads are low....... other than a caliper that doesn't float right... but all 4.... I've got a set of pads on the shelf so were going to let it go another 25K and change them..... at about 125K..... Just a few months...
Jim
Old 12-14-2004, 04:00 PM
mymaur's Avatar
Re: Change your brakes yet?
I love these guys that are getting 90,000 miles out of a set of front brakes. AMAZING!!!! I must be hell on brakes. Have to change out the fronts every 32-35K and rears around 80K. Never tow and my driving is 50% in town and 50% highway.
Old 12-14-2004, 08:44 PM
JHardwick's Avatar
Re: Re: Change your brakes yet?
You must be one of those ............. to the head rest .............. to the dash board kinda drivers
I've been accused of being a tailgater and late braker, but I'm still good to go at 60,000
on edit, it's a 3500 dually that tows heavy quite often .........
Old 12-14-2004, 10:50 PM
Tfeore's Avatar
I've got 32K on the ticker and brakes are squeakin' like crazzzzzy! I just about have the wife convinced I need a new air compressor and some air tools to offset the price of a Dealership inspection......
I gotta take all those lug nuts off some how, don't I????
Hopefully (fingers crossed) I just have lots of dust on the pads. Anybody priced new pads for these beasts yet? I bet DC gets a pretty penny for them.
Old 12-14-2004, 11:35 PM
Steve-l's Avatar
It is called anticipation. You probably drive like my daughter. She drives to every stoplight and stop sign. She never anticipates either slowing or stopping. Remember, it is not just brake use frequency. It is also the rate of decelleration that determines wear. As an exercise, watch the brake lights of the vehicle in front, keeping brake wear in mind. You will see all skill levels from the stupid to the brilliant. Pay close attention to those guys that drive heavy rigs and attempt to use your brakes less frequently than them. You will find the exercise both entertaining and profitable. You too, can then join the 100k club. Here is another tip. In the spring of every year take each wheel appart and clean the brakes of dust and debris. Lightly oil the sliders on single acting calipers and make sure their action is easy and smooth. This will prevent the uneven wear of the pads as well as conserve the rotors. This takes only 30 minutes per wheel.
Steve
Old 12-14-2004, 11:45 PM
J BODY's Avatar
I did brakes on two local 03 3500's that pull rv's or a 3 place car trailer all over the states. Both had over 90K on them and needed brakes (probably 20% left). On the other side of the coin we had an 04 3500 in today with an angry rv'er who only had 42K on his rig and was metal to metal on the fronts and already needed the rears too. I would have to say driving conditions and habits plays a huge part in this scenario. My 01 has 65K on it and still has the original linings at about 30%. I'll be putting new ones on before the racing season starts for me this spring. I feel for those with the 94-98 trucks. I think our new 1500's have more brake friction area than the older 2500's.
Old 12-15-2004, 06:38 AM
nonford's Avatar
I have never had to replace any pads on any of my vehicles before 50K. The earliest I ever replaced any pads was @ 57k, and that was just the fronts. I believe it is all in the habit. I see people riding their brakes all the time. If your 2" inches off someonens bumper all the time, you will be replacing pads much sooner. Those guys that pull all the time and still rack up milage without needing pads speaks alot, they know how to pull. Steve-I used the best word "ANTICIPATION". Know ahead of time and just coast in, you'll be amazed how long your pads will last. I know in the past, that pads were much softer and you could easliy go through them. Today, they are built much better and are more efficient and will last longer. But, the pedal is there and there are people that rely on it with an attitude.
Quick Reply: Change your brakes yet?
