Change Oil from Synthetic back to Dino
Old 05-13-2008, 06:51 PM
ctd4stan's Avatar
I have heard that once you start using 100% syn oil that you can not go back to regular oil. I've read some (not all) the threads re: using syn. At my infant stage, I'm not getting into the discussion of which is better - syn vs. dino
If I use 100% syn at the next oil change, then later decide to go back to regular dino, are there any issues with that? Has anyone done that?
thanks.
Old 05-13-2008, 07:02 PM
Roperteacher's Avatar
No issues at all whatsoever. Syn oil will loosen up sludge in the engine so if you switched BACK to Synthetic I might run a shorter interval the first time before changing it. I have gone back and forth with no problems and great UOA's.
Old 05-13-2008, 09:36 PM
SundayMoney's Avatar
You can swap back and forth as much as you'd like.
Old 05-13-2008, 11:34 PM
dslpwr81's Avatar
As much as you'd like! That was the old synthetics. Doesn't matter now.
Old 05-14-2008, 09:13 AM
DTR 1st Sergeant
soulezoo's Avatar
Yup... not a concern at all.
Old 05-14-2008, 12:39 PM
DBLR's Avatar
Very Good Advice about doing a short OCI after using regular and going back to group 4 or 5 synthetic oil.
Oilburner04
13
11-13-2008 06:03 PM
RHC
35
10-22-2007 05:46 PM
jlipskoc
03-07-2006 06:53 PM
wild4stangs
01-25-2006 08:49 AM
frogspit
01-30-2003 10:26 PM
Quick Reply: Change Oil from Synthetic back to Dino
