Change in engine tone
Old Mar 6, 2005 | 08:30 PM
Dan Brooks's Avatar
Question Change in engine tone
I've noticed something strange over the past couple days. After starting the truck the first time each day or after getting off work, for the first several minutes the engine tone will change - it almost sounds like the KSB is kicking on and off (rattle gets much louder, then quiets down). Once the engine is up to operating temperature it seems to be normal. Haven't noticed any difference in performance of fuel mileage.
Any ideas?
Old Mar 6, 2005 | 08:33 PM
Den's Avatar
Den
While the KSB is energized the enigine will have a different tone. Once you reach 90F (If I remeber correctly) in the intake the KSB kicks off and the engine gets a bit louder.
If it's cycling your either on the edge of the 90 or there may be a bad connection.
I live in a warm climate so once it kicks off it usually stays off. Maybe somebody in a colder climate can answer as well
Den
Old Mar 6, 2005 | 08:37 PM
Dan Brooks's Avatar
I checked the connections and they seemed to be okay. I replaced the sensor that controls the KSB about a month ago. I guess if it continues I'll try disconnecting the KSB and see if it still does it. I'm sure hoping there isn't anything wrong with the injection pump - I'm driving the truck to Oregon next month and don't need any problems....
Pete Miller
Dec 7, 2004 10:05 AM
GONO2
Jul 15, 2004 04:10 PM
EBottema
Apr 9, 2004 02:37 PM
Extreme Diesel
13
Oct 29, 2003 11:23 PM
