Centering Steering Wheel
Old 01-14-2008, 08:34 AM
agalaczy's Avatar
Location: NORTHWEST VERMONT WHERE THE MEN ARE MEN AND THE SHEEP RUN SCARED.
When driving, my steering wheel seems to be tilting a little to the right.it doesn't pull or anyting but that is where it wants to settle.I understand the adjustment for this is on the bar coming off the pitman arm.After loosening the 2 bolts, which way do I turn the adjustment sleeve to bring the steering wheel back to the left?Any help would be appreciated.Thanks,Andy.
Old 01-14-2008, 08:56 AM
RRAMctd's Avatar
I can not figure which to turn it either, I just know you dont have to turn it much to get it work.1/2 turn will probably fix it.Try it one way and see. cant hurt anything, only take a couple min.
Old 01-14-2008, 09:02 AM
RowJ's Avatar
Originally Posted by agalaczy
....After loosening the 2 bolts, which way do I turn the adjustment sleeve to bring the steering wheel back to the left?Any help would be appreciated.Thanks,Andy.
Working from memory but I believe rotating top of bar towards the front moves wheel to left.
As stated above, just try it, or get someone to sit in cab when you move it!
RJ
Old 01-14-2008, 09:17 AM
BPoulsen's Avatar
Thanks! I've got to do this too after I just had my steering box replaced....
Roy3
06-04-2014 05:49 PM
silver_2000_tj
03-03-2011 06:43 PM
qwest
09-29-2008 08:14 AM
RonP
12-02-2005 05:07 PM
MARKY MARK
07-06-2003 10:26 PM
Quick Reply: Centering Steering Wheel
