Cb Radios, Which Is Better?
Old 01-06-2008, 10:07 PM
Pinksa's Avatar
Ive had my General Lee for awhile and was given a Magnum S-3. Which is better, the magnum is more clear sounding, but i want yalls opinions
Thanks in advance- Steven
Old 01-06-2008, 10:57 PM
MikesB12's Avatar
I love my GL, it was modded by Mike at Radio Active Radios. It's holding up really well in my bouncy *** Ford company truck and sounds/recieves great. The Magnum might make more peak wattage, but doesn't receive as well. Also, the Magnums look cheap, IMO.
Old 01-06-2008, 11:33 PM
hyperrcng's Avatar
Which ever you feel does the best for you. I like the Magnum myself. I have the S-6 in my OTR w/a 450 palomar kickin it. The Magnums use a built in pre-amp on the recieve side. If you try and use it like your GL, you may not get the performance like you was seeing with the GL. Magnums are radios that you are always adjusting, mostly receive gain due to the pre-amp. You can squelch out the noise but I find you lose some of your "ears".
The GL is a nice radio, just like most of your imports. You just need a GOOD antenna is set for that radio. I have seen some antennas that the swr's are almost perfect and won't talk or receive worth a darn. Change brands and problem solved.
Good luck
Old 01-06-2008, 11:39 PM
gus's 03's Avatar
i had a general lee done up by mike as well, belive it or not, that thing talks almost as well as my dx95t2, and i think it actualy recives better... i personaly have no experiance with the magnums, ive heard a few on the road that sound great and some that well..... dont...
Old 01-07-2008, 07:18 AM
MikesB12's Avatar
Good luck
I'll second this, it doesn't matter how good the radio is, your antenna can make or break a good setup. I'm having good luck with a Wilson 5000 Mag Mount.
Old 01-07-2008, 04:50 PM
quadman20's Avatar
I've got a Galaxy with the FR limited top gun modulation kit and compression kit (I installed) thats in the Magnum radios. Have quality of Galaxy and punch of a Magnum. Dead 1/2 watt swing 40w and modulation thats off the charts and loud and clear.
Old 01-07-2008, 05:30 PM
Pinksa's Avatar
Well i appreciate all the info...I guess ill just try them both for awhile
Old 01-07-2008, 06:25 PM
#2 only's Avatar
better 4 what? if u like the way your magnum sounds,then maybe your answer is that.if u want more CLEAR audio,then have both checked by a correct meter(bird)
perhaps the best answer will be in your speaker from your listeners!
17
11-28-2004 11:47 PM
Max
22
05-05-2004 07:44 AM
cummingetit
01-14-2004 06:55 PM
dodgeman01
06-15-2003 11:06 PM
DF5152
05-07-2003 05:09 PM
Quick Reply: Cb Radios, Which Is Better?
