CB radio antenna
Old 03-02-2004, 01:02 PM
jrs_dodge_diesel's Avatar
Question CB radio antenna
Howdy y'all,
I want to put a Cb antenna or two if i have too on my truck. I have a magnetic base antenna that will stick to the roof, but after seeing how it scratched up the roof of my last truck, I would much rather not use a magnetic mount. What options are out there for our trucks?
Old 03-02-2004, 01:13 PM
Commatoze's Avatar
You have stake pocket mount, direct cab mount, and fender mount using a firestik bracket made expressly for 2nd gen Rams. Forget about phased antennas. There's not enough room between to generate a favorable pattern. You can add a dummy for a balanced look. Do a search on "antenna" and you'll find copious amounts od helpful info.
Old 03-02-2004, 01:50 PM
Lil Dog's Avatar
I found that with one good antenna (wilson) I had way better luck than with two sticks.
In my 93 trucks, I bolted a mirror mount bracket to the inside of the box on the stake pocket near the driver front of the box. It was out of site and with the window down, you don't get the wind noise from the stick.
I am thinking a fender mount for this 97 as I now have a box cover, now its just finding a good spot for the radio. I was still looking for those special mounts for between the shifter and the seat.
J-eh
Old 03-02-2004, 02:27 PM
BigBlue's Avatar
I've got 2 3' firesticks mounted on opposite sides of the bed right up next to the cab. They are both professionally tuned. I get great reception with them.
Old 03-02-2004, 04:33 PM
phox_mulder's Avatar
Best thing I ever did was pay a visit to Firestik.com.
They have a great technical section regarding SWR, antenna choices, cable choices, mounting locations, etc.
Oh, they also sell everything you need.
phox
Of course, I'm not affiliated with them.
Old 03-02-2004, 05:13 PM
crobtex's Avatar
I put a small piece of cotton bed sheet, just barely larger then the base under my magnetic mount and it never scratched the roof.
My wife wasn't real happy about the rest of the sheet though.
CR
Old 03-02-2004, 05:42 PM
billg's Avatar
J-eh
Lil Dog will this help?
http://www.protintnw.com/sa_dodge-acc.htm
Old 03-02-2004, 05:47 PM
Lil Dog's Avatar
You bet!!
Thanks for the link...
Old 03-02-2004, 08:07 PM
Crimedog's Avatar
I have a set of Diesel brand antennas. They are 3.5 foot whip style, both mounted right between the bed rails and the cab. They are both live, the trick is to get a good ground. I get an SWR reading of 1.2. I get great reception with them, easily miles away, and that is with a low grade radio I have also heard that Firestiks and Francis are good. Francis is a thinner, lower profile antennae, while Diesel and Firestiks are the full on thick fiberglass. Mine look sweet with my truck, now I just need a set of stacks to go with 'em
on edit: I didn't even need to tune these I threw 'em on and hooked up the meter, and they were dead on. Cost me 50 bucks for high grade cable and antennas.
Old 03-03-2004, 07:15 PM
firestorm's Avatar
I haven't done it yet, but JC Whitney has a box with an SWR meter built in that turns your AM/FM antenna into an AM/FM/CB. I am mounting another OEM am/fm antenna on the drivers fender, and hooking it into the box. They call it the Secret CB Antenna, and it's like $25.
Old 03-04-2004, 08:40 AM
matthopp's Avatar
Would the bedrails/bed slot connector work with an over-the-rail toolbox? I have been thinking how to mount an antenna and would like to get one mounted to the bedrails, but my toolbox is there and i dont like the ones that are drill into the tool box.
Old 03-04-2004, 04:13 PM
Crimedog's Avatar
Here is how mine are set up, it is just a piece of 1" flat stock, about 4-5 inches long. Make sure and use at least 1/4 inch, or it will bounce a lot.
on edit: I have painted my sheetmetal screws silver, so now you can't see them
Mechanos
03-30-2005 01:04 PM
96_12V
07-23-2004 02:14 PM
Goldenbear
04-09-2004 05:57 PM
hotdram
09-25-2003 12:09 AM
BigK
01-26-2003 12:58 AM
Quick Reply: CB radio antenna
