cat?
Mornin' Gadget!
Kinda, it's an opacity/smoke particle count test at idle speed on '01's and earlier. '02 & newer gets the OBDII diag. port plugin.
P-pump 12 valvers & CR's require cats in a few counties.
Really? So they actually use a device to measure instead of just a visual test? And with the '02's and newer, do they do the same as the earlier models but also the OBDII?
Yup, the opalcity device "sees" particles in the exhaust stream...looks like a big MAF sensor.
The test dude said a stack is ok as long as they can easily attach the device.
The '02 & newer gets the OBDII port plug-in, no opalcity.
All get a mirror under the truck visual check. No hood opening.
