Carter Lift pump Sensor HELP!!!!
Old 02-22-2008, 01:22 PM
DeathCougar's Avatar
My 99 Ram has a carter frame mount 4601HP lift pump installed. They wired it to a sensor in the block. The sensor acts as switch, and will shut off power to the lift pump when the truck is off.
Today, the lift pump continued to run even with the engine off. That tells me the sensor is bad. The lift pump, wiring, and sensor are remote from anything else in the truck.
The sensor is made by Nason, Part #SM-2A-25R
Can ANYONE help me? I was able to find one online from Nason, but its 4 weeks out and im not 100% sure its even the right part.
I tried checking online for the Carter lift pump kits, but none had an such sensor listed. Help?!?!
Old 02-22-2008, 02:11 PM
OK, well, i think i have it figured out. The Fuel pump cutoff switch, which is controlled by oil pressure, has failed. I have a new switch coming to me today! What a pain in the neck, i thought this stuff never fails! What gives?
I will update this thread when/if I get it fixed.
Big Smoky
03-23-2006 12:11 PM
gfd121
02-19-2006 08:57 AM
HotRod82
17
01-08-2006 06:57 AM
CTD NUT
29
04-04-2005 12:18 PM
IntakeRacing
12-22-2004 05:49 AM
Quick Reply: Carter Lift pump Sensor HELP!!!!
