Carli Adjustible Track Bar install tips?
Old 04-09-2011, 10:17 PM
rootkit's Avatar
Question Carli Adjustible Track Bar install tips?
I plan with in the next week or so installing the carli adjustable track bar to re-align my axles since i am running a 4in lift.
Now my question to the ones that installed it, What torque wrench did you use to get the nut to 200 foot pounds. I dont see getting a socket with the heim on there. Off hand I have no idea what size the nut is and im sure I dont have a wrench for the **** thing so I plan on making a trip to sears would anyone know the size? metric or imperial?
thanks!
Old 04-14-2011, 09:24 PM
losangeleshapa's Avatar
Hope this turned out ok for you.
I would like to know if you are running a stock differential cover? I just purchased a Mag-Hytec front differential cover and am wondering if the steering stabilizer and Trackbar could possibly hit.
Old 04-15-2011, 12:46 AM
rootkit's Avatar
I havent installed it yet but you will be fine. I have the Carli diff guard on.
Old 04-15-2011, 08:07 PM
Nice. Thanks for the response.
Old 04-16-2011, 10:14 AM
LOWTYD's Avatar
Carli track bar install tips.
I believe its a 19mm, but not positive. Really not that hard to accomplish, just make sure once you have your overall installed length correct by adjusting the heim joint end, that you use some blue locktite on the heim threads and torque the jam nut (locktite) as tight as possible. I did my install in the driveway with no issues. No special tools (wrenches and sockets) other than what you need to remove and install both bars. I used a 2ft breaker bar and an impact socket to torque the bar at the both ends. YOU CAN'T GET THEM TOO TIGHT!!!! It's a quality piece and a real solution to the DW. Been running mine for at least 5 years. Good luck.
Old 04-16-2011, 11:50 PM
rootkit's Avatar
The jam nut is 23mm Sears didnt have it in stock so I bought a better adjustable wrench. I'm hoping to get it on this week hopefully and clean up while in under there.
Old 04-17-2011, 06:54 PM
LOWTYD's Avatar
Just a heads up......There is no way an adjustable wrench will get it tight enough. try harbor freight or Northern tool and supply.
Old 04-18-2011, 12:15 AM
rootkit's Avatar
For a normal hand wrench?
I was thinking add a cheater bar should get it up too 200 pounds.
Old 04-29-2011, 08:52 PM
LOWTYD's Avatar
Get that bar on yet?
I was just trying to keep you from crushing your digits with the adjustable wrench. I used a 2 ft breaker bar with an impact socket. I'm sure it saw 200ft/lbs. Just checkin back in.
Old 04-29-2011, 11:33 PM
rootkit's Avatar
Forgot Easter was coming up went hiking with the family will try to get it in this Sunday. So annoying seeing it on the table and not installed haha.
Old 04-29-2011, 11:41 PM
jimbo486's Avatar
Installed one on my dad's truck along with their 3" leveling kit. I used a 24" crescent wrench and slipped a 2ft. pipe over it and put all my weight on it.
losangeleshapa, the track bar (stock and Carli) will make contact with the Mag-Hytec cover. Shawn at Carli told me that Mag-Hytec can grind the diff. cover where it makes contact to remedy the issue. I haven't had the chance to call Mag-Hytec and ask them about this and how much it'll cost. I say send it back and keep your stock diff. cover. The front diff. doesn't get nearly as hot as the rear 'cause the rear is doing most of the work. Even when locked in 4wd.
Old 04-30-2011, 01:01 PM
rootkit's Avatar
Just last week I saw a 06 with the mag cover on with the same trac bar... I ask if he had any problems or any grinding he said no...
I wonder if mag-hytec already did that for the new covers being sent out...
Old 05-15-2011, 09:18 PM
rootkit's Avatar
Installed the trackbar little clunk turning left to right guessing the jam nut isnt tight enough going to give it a shot again tomorrow.
Dane
12-17-2011 03:30 PM
CTD2001
08-22-2009 10:03 PM
silkywoods
12-08-2007 04:23 PM
silkywoods
11-10-2007 03:52 PM
John Faughn
12-20-2006 08:21 AM
Quick Reply: Carli Adjustible Track Bar install tips?
