cargo limits for srw 2500 4x4
Old 03-09-2010, 09:44 AM
ultramag's Avatar
Guys i need some help here. planning a trip to minneapolis to pick up a lift of hardwood flooring weight is 2700lbs.mow i have a 2004 2500 cummins shortbox 4x4 with load range "E" tires.this is a straight shot on the interstate of 500 miles.will this be way over limit for my truck.the load will not be very tall so i don't think it will be "tippy"
Old 03-09-2010, 10:07 AM
knc77's Avatar
While the truck may handle the weight, you will likely be over the GVWR. From what I have read on the boards, the various state DOTs seem to be tightening up on things like that. Do you have a small trailer you could use? Might save you a ticket and make for a more comfortable ride.
Old 03-09-2010, 10:29 AM
Midnite's Avatar
I agree a trailer would be ideal. If you can't do a trailer though, then I'd suggest max sidewall pressure in your front tires and 10% over in your rears (88 psi instead of 80). Stop frequently and put your hand to the rear tire sidewalls and feel how hot they are. You may have to drive slower than you want.
Mike
Old 03-09-2010, 11:35 AM
Busboy's Avatar
Truck should be about 7200-7500lbs your GVWR 8800lbs or 9000lbs. it is on the sticker on the drivers door jamb. if you go with the highest GVWR and the lowest weight you still only have 1800lbs of usable load. The truck can handle it no problem but legally you will be over the GVWR for your truck.
Old 03-09-2010, 11:49 AM
nkennedy's Avatar
Dodge's 8800 lb GVWR doesn't mean nothing legaly. Whatever your registration says is what you need to stay under. That & your GAWR & tire caps.
Old 03-09-2010, 01:33 PM
pdogg's Avatar
if you check the specs for the payload of the bed, I do believe you're still under the ~2780lbs limit.. check spec sheet to be sure..
Old 03-09-2010, 01:35 PM
troll3193's Avatar
I had an 04 2500 4x4. With me and a full tank of fuel it was around 7200-7300lbs... and GVWR was 9000lbs...
So you will be over a bit.. Will probably work though...
Bryan
Old 03-09-2010, 03:32 PM
DTR's Toad Wrangler
Clayten's Avatar
I had mine licensed and insured for 12,500 lb.
Old 03-14-2010, 08:47 PM
2003Ram's Avatar
I had 4200 lbs of dirt and rock for a short haul once. The truck did fine.
Old 03-14-2010, 10:40 PM
bkrukow's Avatar
I burn corn for heat and before I bought my corn wagon I used to haul it home in the box of the truck. A short box truck will hold exactly 40 bushel of corn at 52lbs/bushel thats 2080 pounds. It barely squated my 04 2500. It basicaly made it sit level. I only had to go abought 8 miles with it but I wouldent have hesitated to go farther though. If ya have good tires ide say go for it.
MikeRP
79
11-21-2016 10:19 PM
Shipskym
02-05-2014 11:27 AM
serious
10-09-2010 07:15 PM
rcts
11-21-2009 11:29 AM
dragginlx
15
03-09-2007 11:32 AM
Quick Reply: cargo limits for srw 2500 4x4
