capping the rail versus dual feed line
Old 06-12-2007, 11:27 PM
morkable's Avatar
I was wondering which would be better. I am getting info on both sides and I am wondering what all of you feel
Kevin
Old 06-12-2007, 11:40 PM
Luvnacumns's Avatar
Kevin
I'd like to know I have the dual feed line sitting in my truck seat now.. Just keep getting mixed reviews???
Old 06-12-2007, 11:41 PM
973604x4's Avatar
How bout dual feed and a relief valve? Look at the Relentless Y fitting.
Old 06-12-2007, 11:46 PM
Luvnacumns's Avatar
That was what I was wondering.. I'd heard so much bad about loosing the relief valve??? Link???
Old 06-12-2007, 11:54 PM
973604x4's Avatar
http://relentlessdiesel.com/forum/viewtopic.php?t=25
second pic
Old 06-13-2007, 12:00 AM
Luvnacumns's Avatar
Thanks, Phil.. Iwill have to call Stephanie and chat with her!!
Old 06-13-2007, 12:37 AM
973604x4's Avatar
I need to do the same. Need to have them try to mod my FCA again. It sure is nice having Relentless an hour down the road
Old 06-13-2007, 07:21 AM
abc4yew's Avatar
Will the 2007 6.7 relief valve fit the 5.9 rail?....It is good for a little higher pressure like 1600psi more or something close to that. When the manufacturer raises the pressure level...it must have some positive benefits. ks
Old 06-13-2007, 08:16 AM
Luvnacumns's Avatar
That would be nice!!!
Kerry, I am not sure but I will ask!!
Old 06-13-2007, 02:59 PM
morkable's Avatar
what are the cons to capping the relief valve?
Kevin
Old 06-13-2007, 04:23 PM
wap
wap's Avatar
Mine is capped cause I blew my RV and it was cheap and I was in a tight.
Cons, there is no cusion for you injectors. You can crack injectors with a RV in place but I guess it is less likely. With a cap you have no give. I assume this is common knowledge but that is the only cons I can see.
So far no problems with mine, but if I had one I would run a RV. Besides the hp, that is one reason I am set on Flux injectors, less likely to crack a tip.
Old 06-14-2007, 10:51 AM
morkable's Avatar
What is the procedure to cap the relief valve?
Kevin
Old 06-14-2007, 12:00 PM
wap
wap's Avatar
Take the bolt out of the top, move the line out of the way, take the rv itself out, then replace with the "cap", the put the line back in place, and replace bolt on top.
If you need some more help shoot me a pm and I can give you my #. It is very simple.
Old 06-14-2007, 12:15 PM
ramtd02's Avatar
do the relief valves on these trucks re-seat themselves?? If not how do you tell if you blew one?
Old 06-14-2007, 12:18 PM
wap
wap's Avatar
No, they do not reset themselves. My truck shut off and would not crank back up. At first I did not know that was the cause, but the blown rv was the problem.
Also if you have a rail guage, if you can t get pressure as high as it should then your rv could be goin south. If you are loosin power up top, another indication.
Quick Reply: capping the rail versus dual feed line
