Can't tighten ball
Can't tighten ball
I have a Putnam Levelride round bar weight distribution system. I can not get a socket that will fit in the hitch head to tighten the nut for the ball. The socket size needed is 1 7/8", but it is to big for the space where the nut resides. How the heck am I supposed to tighten this thing to 450ftlbs without a socket?
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
Thin walled socket and an air impact. Where are you at here in SD? I think we have just what you need down in the shop. I'll go look.
I always use a pipe wrench (usually an 18") and tighten it till it just won't turn no mo. Never ever had a ball come loose with this method and I've pulled some heavy stuff.
[QUOTE][/Thin walled socket and an air impact. Where are you at here in SD? I think we have just what you need down in the shop. I'll go look.
QUOTE]
Sounds like it would do the trick. I live in Campo, but work at Miramar.
QUOTE]
1 Post
I'm also in Miramar. Well, just on the south side of the MCAS. How deep does the socket have to be? I have several here; one of which is 2" deep.
Put some antisieze on the threads will cure that problum
I faced the same problem. Tightened the nut with a crescent wrench until the lock washer compressed all the way, then the socket I had (standard 3/4" drive) would fit, so I torqued it to the recommended 450 ft/lbs.
1985cucv
07-06-2009 04:38 PM
Common
08-03-2006 10:11 AM
