Can't see the darn gear oil on the dipstick!
Old 09-18-2005, 07:57 PM
Commatoze's Avatar
I drained differential today and installed my new Mag-Hytec Dana 60 differential cover and filled it with Mobil1 gear oil. The problem I'm having is that I can't see the gear oil on the dip stick. It's too light in color. I'm wondering if there is a dye that I can add to the gear oil so I can see it on the stick? By the way, the newly revised vented cover works great.
Old 09-18-2005, 08:03 PM
hotdram's Avatar
Commatoze,
No clue on the dye, so can't help you there, but had a question about the install on the Mag Hytec. Did you have to remove any of the front suspension/steering components to get the new Mag Hytec in there?
(What about shining a flashlight on the dipstick, that's what I do when I check my rear end).
~Rob
Old 09-18-2005, 09:09 PM
Geico266's Avatar
Originally Posted by hotdram
Commatoze,
.......And just how often do you check your rear end with a flashlight and...... what are you looking for? Monkees?
I just could not leave this one alone.
Sorry Rob!
Old 09-18-2005, 09:10 PM
Homestead's Avatar
How has the cover been "revised"?
I've been waiting to see what was going to happen with this revision before I went ahead and picked up my covers.
Old 09-19-2005, 06:45 AM
Commatoze's Avatar
.....Did you have to remove any of the front suspension/steering components to get the new Mag Hytec in there?......
Yes, you must drop the driver's side tie rod end. Just loosen the nut all the way, and wail on the stud a couple of times with a mallet and it drops free. To re-insert, I used the truck's little jack under the tie rod end to apply slight pressure to it to hold the taper in place and keep it from spinning while I tightened the lock nut up
They've added a baffle around the dipstick to prevent gear oil from splashing up on the vent hole in the stick and eventually burping out the vent. I went thru that 2 years ago, and what a mess that was! Drove 40 miles this morning, and no leaks. Also, it looks
Old 09-19-2005, 10:10 AM
hotdram's Avatar
I only check it when it makes funny noises or binds up going around corners (I'm talking the Dana 80 in my truck, is that what you meant?).
I read this about 20 minutes after I posted it and realized what I had said and how wide open I left myself. I was going to change it, but I figured I deserved whatever I got.
Back on topic,
I am going to have to check on the new design Dana 60 cover, that sounds cool. I am waiting to see if anyone has any thoughts on the dye too. Wonder if food coloring would work?
~Rob
Old 09-19-2005, 10:48 AM
PistolWhipt's Avatar
Sorry Rob!
Oh my God .... I can't believe you went there !!! That was hilarious !!!
PISTOL
Old 09-19-2005, 02:04 PM
HappyGA's Avatar
Dipstick on DIffs??
Is that something that the mag-hytechs have made into them or am i just blind when I crawl under?
Old 09-19-2005, 02:23 PM
hotdram's Avatar
Originally Posted by HappyGA
Dipstick on DIffs??
Yes, the Mag-Hytecs have dipsticks on them.
Mag-Hytec makes front and rear diff covers and tranny pans (for those that don't row their own )
~Rob
Old 09-20-2005, 07:25 AM
hotdram's Avatar
I emailed Mag-Hytec about a dye, still waiting on their response.
~Rob
Old 09-20-2005, 07:57 AM
HappyGA's Avatar
Why couldn't you add in some food coloring?
Old 09-20-2005, 08:23 AM
Flashdancr's Avatar
Sorry Rob!
That was toooooo funny!
Now back on topic. Why can't you put a piece of masking tape on the dip stick and then take it off after you check your fluid level.
Old 09-20-2005, 08:46 AM
Mopar1973man's Avatar
I was going to say the same thing... Blue or red would be really good colors...
Old 09-21-2005, 09:26 PM
Geico266's Avatar
Food coloring is water based and not a good thing to add to oil. Just tip the dipstick in the light. You'll see the mark.
Old 09-21-2005, 09:43 PM
Hayseed's Avatar
You can rough up the dipstick w/ sandblaster or sandpaper(fine) and the oil will show up on the dull surface. Had to do this with my farm tractor hydraulic fluid, it is clear as well.
Quick Reply: Can't see the darn gear oil on the dipstick!
