can't find 4" turbo back exahust 92 dodge
Old 01-18-2010, 04:25 PM
The Yeti's Avatar
the exahust is rotted off of my truck so i figured i'd up grade it to 4" or 5" at the same time, my issue is that all the exahust systems that i have found for dodge cummins are for 94 and newer.
i need the full turbo back because of the prevous owner hacked it to **** and thus it rotted off.
will a system for a 94 work for me? or will i have to get one custom made?
thanks
Christian
Old 01-18-2010, 04:31 PM
jimbo486's Avatar
http://www.sourceautomotive.biz/shop/index.php should be able to get you set up with a 4" turbo back. or at least a 4" downpipe to get you started if you wanna build your own system. a system from a '94 would work. however, you'd need the cast elbow that comes off of the turbo for that downpipe to bolt up.
Old 01-18-2010, 04:36 PM
www.stansheaders.com
makes the best 4" turbo back system for 1st gens.
Old 01-18-2010, 05:20 PM
Rick 12v CTD's Avatar
how would their's be better than the one from source?
Old 01-18-2010, 05:52 PM
14racing's Avatar
X2 on That!
I'm not sure about any of the other brands but the stans system is amazing. All mandrel bent and fits great. I don't see how anyone could make one that is any better.
Attached Thumbnails can't find 4" turbo back exahust 92 dodge-exhaust.jpg   can't find 4" turbo back exahust 92 dodge-exhaust2.jpg
Old 01-18-2010, 07:40 PM
Source only makes 4" systems for 4x4 trucks with the T-case pipe.
Old 01-18-2010, 08:58 PM
this is true. I forgot about that and I got my 4" system from Source lol
Old 01-19-2010, 12:16 AM
peobryant's Avatar
I talked to Rip when I was looking for a 4" exhaust and he told me he would "modify" the order so it would fit a 2wd.
Old 01-19-2010, 01:24 AM
Best Paint (Getrag category)
pulltilbroke's Avatar
I have no experiance with Rip's setup nor have I seen one in person but I havn't heard anything bad about his system. I do however have experiance with the Stans parts and can tell you that they are top notch quality, when I got mine I just ordered the DP and t-case pipe cause I was running a single stack setup at the time. I am now running the Stans stuff from the turbo to the back of the t-case with a homade muff delete with an old Flo-Pro 4" tail section made for a 1st gen.
Old 01-19-2010, 05:20 PM
The Yeti's Avatar
thanks guys looks good again the issue is i'm in canada i have found a parts guy that can get me the bully dog turbo back exahust system for $550 any major conserns with regard to that system?'
also i really want to put stacks on the truck eventualy but if i'm doing the exahust now i might consider it. "pulltilbroke" how did you have your stack mounted in the bed?
Old 01-19-2010, 05:33 PM
james1's Avatar
Smile Old threads are your friends Yeti-san...
I visited Stan's shop:
https://www.dieseltruckresource.com/...ht=Phil+Fuller
I think it would be difficult to find nicer folks to do business with.
Old 01-19-2010, 06:25 PM
This is how my stack was mounted
Old 01-19-2010, 06:54 PM
The Yeti's Avatar
great thanks, i was un sure how to mount them to the box
thanks for the pics
CB
Old 01-19-2010, 08:18 PM
COUNTRYBOY's Avatar
Don't waste your money on the Bully Dog system, it's not a true 4" turbo back, go with either Rips or Stans.... I have the Pinnicle exhaust and it's not a true 4" either, it's 3.5 for the first 8" or so then 4" the rest of the way back. I have a Aero Turbine muffler "4040" and really like my set up...
Old 01-19-2010, 08:39 PM
dstad's Avatar
I just got rips for christmass for my 91 d250. I love it, it cooled it don a crap ton, gave me a good deep sound and the drone was minimal, when you romp on it, it isnt obnxious. Def worth every penny. I would highly recomend it.
Quick Reply: can't find 4" turbo back exahust 92 dodge
