Can't erase code 0113
Old 09-16-2005, 03:46 PM
CTD99's Avatar
When I first installed my Edge a year or so ago, I got this code but I erased it with my code scanner and it never came back. After my recent rebuild, I've got the code again and when I erase it, it immediately pops up again. Could the sensor really be bad? It was perfectly clean when I reassemble the engine.
Thanks.
~Russ
Old 09-16-2005, 03:50 PM
phox_mulder's Avatar
Yes, it could very well be bad.
Just because it's clean doesn't mean it's working right.
phox
Old 09-17-2005, 07:32 AM
Mopar1973man's Avatar
If the code is popping right up... I would say the sensor is bad.
But double check that you haven't crushed any wires... I know you just got done rebuilding the engine...
Old 09-18-2005, 12:27 PM
CTD99's Avatar
Ok... just in case anybody was wondering... If you don't connect the IAT sensor you will get an 0113 code and it will immediately pop up again when you try to erase it.
I came across a loose connector yesterday so I posted a pic in my thread "Where does this go?"... "It's the IAT" they said... and I thought, "No, couldn't be!" but sure enough, it was, and I'm an idiot.
Is it possible to spend too much time working on your truck? I think I'm losing my mind...
~ Russ
Old 09-18-2005, 07:35 PM
darkstarmedia's Avatar
I think Ozzy Osborne had an applicable quote....
"Of all the things I've lost, I miss my mind the most."
Old 09-18-2005, 07:43 PM
Haulin_in_Dixie's Avatar
~ Russ
Yes........
OldDodgeOwner
08-20-2009 08:48 PM
sallyman1
08-26-2008 08:30 AM
Joe Diesel
11-12-2007 08:59 AM
jdog
03-12-2007 08:12 PM
Mike M
08-10-2006 12:07 PM
Quick Reply: Can't erase code 0113
