can you just remove the exhaust manifold and not the turbo?
Old 11-09-2009, 05:22 AM
1985cucv's Avatar
i was wondering if it would be easier to just remove the exhaust manifold and not the turbo? or do you have to remove both at the same time? thanks
Old 11-09-2009, 05:57 AM
Administrator/Jarhead
madhat's Avatar
Yes, you can, but I would support the turbo after you disconnect it from the manifold, like tie it up so that the exhaust does not have the weight on it.
Why are you removing the manifold? That might help answer your question better.
Old 11-09-2009, 06:19 AM
Load Hauler 04's Avatar
I changed my exhaust gaskets without pulling the turbo. You must support the turbo/exhaust, I used a floor jack...
Old 11-09-2009, 09:18 PM
1985cucv's Avatar
why am i going to remove it i am either gonna get an aftermarket one or i am going to port the stock one. i ported the stocker on my first gen and it mad ea huge difference. egts didnt rise nearly as quick and spool up was right there, plus i might put a egt probe in
Old 11-09-2009, 09:29 PM
madhat's Avatar
Yeah, just support it.
Old 11-09-2009, 10:31 PM
CD in NM's Avatar
I just changed out my exhaust manifold installed an aftermarket header, I just put a jack stand under the turbo, did fine, didn't move, bolted up without any issues.
CD
Old 11-10-2009, 05:13 AM
1985cucv's Avatar
good deal thats what i like to hear
Old 11-11-2009, 07:22 AM
CRToney's Avatar
I bought an ATS and dropped 2psi of boost when cruising @ 70mph. The stocker is prone to crack. I would buy an ATS for that fact. I would hate to spend all that time and have it crack in the future. Ad Removed The manifolds off of the '06 and newer trucks are supposed to flow better at #5 cyl (correct me if I'm wrong) than the earlier ones and are not supposed to crack as easy. Have fun.
Old 11-15-2009, 08:45 AM
1985cucv's Avatar
it really doesnt take all that long to port it out. prolly like 2 hours and was definitly worth it on my first gen
Old 11-15-2009, 12:17 PM
Dodgezilla's Avatar
If your downpipe is still connected to that bracket bolted to the side of the bellhousing then I don't see why you would really need to support it. Nothing wrong with playing it safe though....
RoadDiesel
08-07-2012 06:06 PM
zooey69
15
03-02-2006 05:06 PM
Dodgezilla
07-17-2004 05:24 AM
j
01-09-2004 08:19 AM
Quick Reply: can you just remove the exhaust manifold and not the turbo?
