How can I tell if my cat died?
Old 05-11-2008, 04:10 PM
Ram Guy's Avatar
The sound of my truck has changed somewhat...Not engine noise but exhaust noise.It sounds like it is 'working' when driving it (this doesn't even make sense to me).I don't have a gauge for Ex temp so is there a way I could tell if my CAT is plugging up?
Old 05-11-2008, 05:06 PM
Dodgezilla's Avatar
He will usually be laying on his side with his tongue hanging out of his mouth. He will be kind of stiff too if he's been dead for a while....
Seriously though, I think if the cat was clogged your truck would run like crap....
Old 05-11-2008, 05:22 PM
Administrator/Jarhead
madhat's Avatar
I did not think that an 03 had a cat... I could be totally wrong, tho...
Old 05-11-2008, 05:25 PM
chipmonk's Avatar
beat me to it! you gotta be quick around here.
Old 05-11-2008, 05:33 PM
snoyes's Avatar
I agree, didn't think the 03 had a Cat unless it was a Cali edition? And Dodgezilla beat us all on the dead cat joke....
Old 05-11-2008, 05:34 PM
exolent's Avatar
Possible that the truck has just broken in? Ive heard around that noises change etc when everything finally settles and its broken in
Old 05-11-2008, 05:46 PM
87BRGN's Avatar
Check for exhaust leaks. with the truck idleing, start at the turbo and work your way back. especially around the muffler. My bro in laws 04 had a odd exhaust note, turned out to be the muffler was starting to get a rust hole in the bottom front of it. Like the others said no cat on yours.
Dave
Old 05-11-2008, 06:43 PM
SjLingenfelter's Avatar
2003s dont have cats for sure unless cali edition
Old 05-11-2008, 06:59 PM
Dodgezilla's Avatar
Yup the Cali edition had a CAT and I remember reading that one of the New England states also got the Cali SO. His truck is an SO too.
I know one thing. My 03 sounded much different at 75000 miles than it did when new. It was much louder and better sounding.....
Oh, one more thing. Yes you must be quick around here. I am the master...
Old 05-12-2008, 01:58 AM
Ram Guy's Avatar
Yeah!!!I sure wish I would have looked first...No cat!I just assumed that it had one.However,it still sounds like it is possibly laboring a little more than usual.Maybe I'm just parinoid.I will start looking for exhaust leaks.If all else fails I could just go buy a cat and have it killed.
Old 05-12-2008, 04:37 AM
Jim Lane's Avatar
Post
You don’t have a Pyrometer? Rule #1
I only have a 1st... Gen but if the cat was blocked it would have excessive backpressure and would probably be making wheezing or a sick chirping sound from the turbo since it would be trying to stuff air into someplace it couldn't go. If it was completely blocked the truck would barely rev or even run and you could possibly blow your muffler or cat off while trying.
I have had cat's plug up to this point on gassers when the internals collapse because they by nature get extremely hot.
Probably the easiest way to check if it is blocked is to crawl under and disconnect the head pipe and then start the truck, you could tell if it was blocked but not just sounding different, checking the backpressure would do that.
You are not hearing the turbo whine are you?
Also to my experience the best way to find if you cat has died is if in about 3 days you can stand it back up and it stays there.
Jim
Old 05-12-2008, 05:15 AM
haftrek's Avatar
I was not aware that you could buy a Dodge with a cat. I thought thwy only came with a Cummins.
Old 05-12-2008, 06:49 AM
Jim Lane's Avatar
Post
I hope were in reference to a Catalytic Converter and not a yellow Caterpillar if not oops.
Jim
tyroneweaver
01-04-2013 09:26 AM
Totallyrad
07-19-2011 07:41 AM
Tommy93w350
20
11-01-2005 11:07 PM
Paul Winey
01-10-2003 05:50 PM
OH Sick
12-10-2002 04:32 PM
Quick Reply: How can I tell if my cat died?
