can i stack two chips
Old Aug 1, 2007 | 01:06 PM
TexMexCowboy's Avatar
I have a Old School Van Aiken that connects to the Injection pump. There is sombody wanting to sell me a edge chip that connects to the MAP sensor. and i was woundering if i could connect them both and not have a problem.
So can i connect them both since the Van aiken connects to the Injection pump and the other one connects to the MAP sensor.
Old Aug 1, 2007 | 02:53 PM
R.T.D.H.S.P.'s Avatar
Depends if the Edge chip connects to the IP wire also. If so, not really an option.
Old Aug 1, 2007 | 03:07 PM
qzilla's Avatar
You need a wire tap only box.
I think Blue Chip, TST and OUr XZillaraider modules are the only ones that do that. Any of those will stack nicely.
Old Aug 1, 2007 | 04:58 PM
ok you lost me explain it in red neck words lol. what do you mean i need a wire tape only box? and if i get the xzillaraider you are saying that i can stack it with my Van Aiken?
Old Aug 1, 2007 | 05:02 PM
dodgezilla04's Avatar
pringles work best for this, as they are of a uniform shape...
sorry, couldnt resist.
Old Aug 1, 2007 | 05:34 PM
Fishin2Deep4U's Avatar
You need a fueling only box that does NOT add timing. The van Aaken is supplying the engine wit it's own timing as a way to increase power. So, you need a box like the TST that only sends a fueling pulse and does not provide it's own timing.
Some timing good, Too much timing bad.
Dave
Old Aug 1, 2007 | 08:14 PM
Adam3291's Avatar
Forget the box and get a programmer, a Smarty is a nice investment. I'm not running my Smarty all the time due to have a stock tranny but I love it for the simple fact you can check codes.
Old Aug 1, 2007 | 09:55 PM
Well one thing abou the smarty its EXPENSIVE and the last thing somebody told me was not to use a programer becouse my truck wont be that great with a programer unless i put a diffrent tranny and bigger injectors and stuff like that.
Also you think my Van Aiken does add timing? All I know that think connects to the injection pump and thats it.
Old Aug 1, 2007 | 10:02 PM
HOHN's Avatar
Dave
Better to add no timing at all than to add too much.
jh
Old Aug 1, 2007 | 10:06 PM
HOHN's Avatar
The Van Aaken does advance the timing a little, but nothing radical. It's a great all-around box. I had one (though it was a newer one that plugged in like an EZ does).
I actually preferred it over the Edge box because the VA was quieter. The Edge added enough timing to increase the rattle of the engine noticeably.
I never saw a difference in MPG between them, so while it SOUNDS like the EZ adds a lot more timing, I didn't see any real-world effect of it upon mpg.
Be advised that some of the older VA boxes did NOT do boost fooling-- meaning the truck would defuel and limit boost to the factory spec of ~21psi. This is bad.
So find out if this VA box has a built-in boost fooler, because you'll want one.
If it doesn't and you still want the box, you can get boost foolers from www.psdieselproducts.com for a good price.
EDIT: never mind, PS is out of business apparently. Musta been the PowerStroke resemblance
JH
coon-dog7070
May 25, 2009 09:54 PM
91.5 beater
Aug 13, 2008 08:47 AM
Smokin98.5
Apr 9, 2008 02:21 PM
Juiced01z06
18
Feb 13, 2007 11:46 PM
Jvenne86
Jan 26, 2007 11:03 PM
