What can I stack with the comp
Old Mar 6, 2006 | 06:45 PM
jeeptjstud's Avatar
Are there any chips to stack with the comp, or should I just upgrade to the drag comp? Any input?
Old Mar 6, 2006 | 10:31 PM
Kman9090's Avatar
I've heard that the smarty and the comp are a good combo. But im not for sure you might try a search for smarty's
Old Mar 7, 2006 | 08:03 AM
Ph4tty's Avatar
Comp does fueling and timing, so as is smarty is a good option and I suspect that stack would net around the same max hp gain as a drag comp- although I'm going out on a limb saying this. Smarty will add a lot to the low end and eliminate the top end defuel.
The other route would be to unplug the tap on the comp and run it in ez mode then add a fueling box from Blue chip or TST. The highest powered 2nd gen on DTR is running a redline box with the comp unplugged fwiw.
Old Mar 7, 2006 | 09:15 AM
SuperDave4x4's Avatar
I say skip the stack and get some bigger injectors. Mach 6s maybe???
Old Mar 7, 2006 | 07:36 PM
HP Upgrades's Avatar
I would wait just a little while and stack your Comp with a TS Performance MP-8 power module. I have heard that this will be an awesome combo, and our customers are loving the performance they are getting with the TS Performance chips.
Old Mar 7, 2006 | 10:07 PM
I'm guessing the TS chip is just a fueling box, correct? I don't know much about it.
Old Mar 8, 2006 | 06:56 AM
Ph4tty's Avatar
I went with 4's and wish I would have gone with 6's. You'll need some air and some tranny work adding all that power. BTW- the TS is for CR and won't work with the 99 according to HP's link
Totallyrad
Jul 19, 2011 07:41 AM
nasty01cummims
May 23, 2009 10:24 PM
szwayka111
Sep 18, 2007 09:35 AM
dodgediesel
Jul 27, 2007 08:59 AM
Sea01Cummer
Oct 24, 2005 01:24 PM
