Can Opie bypass get air pocket?
Old 07-29-2009, 05:38 PM
nrussell's Avatar
Just wondering if it's possible, because i don't see much of a temp change.How can you tell if it's even working?
thanks
Old 07-29-2009, 08:24 PM
Spooler's Avatar
You won't see much, I did have to blead mine on the initial install before the valve and after to get all the air out. If it did have air your temps would be higher, mine were.
Old 07-29-2009, 08:38 PM
nrussell's Avatar
temps are normal. when you bleed it, did you just disconnect back fitting on bypass?
Old 07-29-2009, 11:19 PM
WUnderwood's Avatar
is the hose coming out of the valve hot?
Old 07-30-2009, 02:47 PM
Spooler's Avatar
Yes, just loosened it up until antifreeze came out while running, then tightened.
Old 07-30-2009, 03:44 PM
nrussell's Avatar
Yeah I'm good to go now.
Old 07-30-2009, 04:16 PM
Spooler's Avatar
Did bleeding it fix the problem. Getting the air pocket out of my truck was a pain until I finally did this. Problem solved.
Old 07-30-2009, 04:27 PM
nrussell's Avatar
yes it did, i'm good. thanks
Bswope
76
05-22-2009 06:20 PM
82NDSNPR
29
03-20-2009 06:37 PM
Timinva
79
03-03-2009 06:38 PM
Dwitt0187
38
11-08-2008 01:55 PM
Quick Reply: Can Opie bypass get air pocket?
