Can I mount 235/85/16 on my stock 2500 Rims
Like the title says, I want to know if I can mount 235/85/16's on my stock 2500 rims(they are steel that are chromed). I would like to run them due to being taller and narrower then my current tires but was worried the rim may be to wide thoughts, anyone currently doing this, pictures?
It's actually hard to say whether it's possible without knowing what size the rims are. What's your stock tire size?
The stock tire size on my 2000 2500 was 265/75R16, and those are too wide for a 235 tire. 255/85R16 just barely fit. My stock rims are cast aluminum though, so they may not be the same size as yours.
I have stock steel rims that are chrome plate, the OEM size was 245/75/16, currently running 265's
Okay, that makes sense. I think the earlier 2nd gens came with 245/75R16s and then at some point they changed over to the 265s. Mine are definitely stock, and it's a 2000, so mine might've been the first year for the bigger tire.
Regardless, it sounds like your rims should work fine with the 235s.
Totallyrad
07-19-2011 07:41 AM
1985cucv
09-11-2009 06:54 PM
nvr-enuf
07-12-2009 09:55 PM
CG98x
02-16-2007 09:01 PM
moparguy
01-28-2005 02:55 PM
